DIY: How to Remove an Engine
This my first time removing an engine from a car. It was an amazing learning experience, and I did (most) of it myself! I documented some of the major steps in the video below:
The engine and transmission were removed from my 2001 Toyota Corolla. I opted to disassemble major components off of the engine in the car before removing the assembly. If your doing a straight engine swap, you can skip those steps.
Here’s a few photos of the procedure:
Lower radiator hose, water pump and thermostat
Radiator
A/c Compressor
Air intake, battery and air box
Exhaust manifold
Now the engine bay should look like this
A/C condenser
Power steering pump
Starter
Transmission shift cable and linkage
Hoses, fuel lines and wiring harness. Note, the manual says to remove the harness from the ECU inside the car.
Drain fluids
Axle nut
BF pry bar to remove axles
Engine has four engine mounts, front, rear (under the steering rack), transmission and engine side
Support engine
Rear mount bolts
Front mount bolts. Mine was stuck in the bushing
Tranny mount will have to come off the fender to be lifted up
Engine side mount
Now everything is resting on the jack stands below
Strap it up. I used a big chain and seat belts to stabilize it.
Once its high enough, I rolled the car backward
That wheel gap!
Finally installed the engine on its stand
Radiator
A/c Compressor
Exhaust manifold
A/C condenser
Power steering pump
Starter
Drain fluids
Axle nut
Support engine
Rear mount bolts
Engine side mount
That wheel gap!
Nice post, speedkar, but this is probably better-suited for the Maintenance forum.
https://www.clublexus.com/forums/maintenance-11/
Looks like an up north car, how many of those rusted *** bolts gave you a fight?????
Also just wondering, how many miles on the car?? And why did you decide to replace the engine, rather than move onto something else. . . .
I know here in the south, where cars don't rust, if we saw something that rusty and needed serious engine work, its off the the junk yard. We don't work on rusty **** here in the south.
I'm tearing this car apart to learn how it works, this is purely for fun and learning, I'm not putting it back together
That being said, do you want to see videos on how anything else works?
And yes the engine in this car is quite small once you strip down all the components around the engine bay.
Ezz4001
02-03-18 10:51 AM
