VLOG: Should a driver use traction control on track ? ?
New VLOG I did to share my insights after 27 track days on 11 circuits. When to use it, why we use it, and why some dont ! Hope you enjoy!
Tech Info Resource
That's funny. I ran with the stability control on in my IS F and lost my front brakes (Carbotech XP12 track pads) in the third session of my first track day because they were intervening so much. I NEVER drive with it on because it creates a false sense of what your car can do when it really can't. Maybe blame that on years of road racing motorcycles, and using aggressive throttle, but leaving it on nearly caused me to lose my car on my first track day. Never again.
Airbags saving people on the track? Never happened. I know more people who were unnecessarily injured by airbags on track days than I do people who were saved by getting a Mike Tyson punch.
Sorry, but I violently disagree with this.
.Not all vsc/dtc systems are the same though. Some kick in really early and harsh. Others are much smoother and progressive. On the track, I prefer not using it. On the road I always keep it on, the nanny could save you during a abrupt avoidance maneuver. I had some connections at the GM Milford proving grounds. Got to spend time on the seven sisters track. After the first time with re11's on the car, I was told next time come with a set of used A/S tires. When I asked why, I was told the tires were covering up flaws in my driving. Doing so made me a much better driver. I would see the cars nanny doing the same thing as a stickier tire.
Traction/stability control has come a long way over the years, the stuff on sports cars from the past 5-6 years is LIGHT YEARS ahead of similar systems used in the late 90's/00's
Tech Info Resource
I have never fully understood why so many guys show up to an HPDE with high grip tires. You learn so much more in low traction conditions. If it's a race, sure, run the stickiest stuff you can get because you want every possible advantage, but an HPDE? No times, no trophies, no purses, not even decent bragging rights because you never know if anyone else at the event has any skill - most often, there are only a very few genuinely fast drivers at an HPDE, and they're just testing so they're not going all out either. You are way better off just running your street tires and actually learning something.
Why you say is true, but it is also wise (assuming the T/C and VSC are turned off) to err on the side of safety. Once you're in the ditch, or have damaged your car (and maybe yourself as well), it's too late to then say "Gee, maybe I should have used sticker tires".
As for the tire thing, I'd say it depends on how much of a beast you are driving. Some of these newer cars with 500+hp stock, put crappy tires on them and you can't put down the power coming out of a corner.
A lot of rookie track day guys with no previous auto-x/road racing experience also make the mistake of buying too much car. Start in something slow with less grip like a Miata, once you've figured that out move into something faster, it will make you a better driver.
Tech Info Resource
NEVER TRACK A CAR/BIKE YOU CAN'T AFFORD TO THROW AWAY.
