Now my 4Runner has an issue
Old 11-27-17, 07:05 AM
  #31
Originally Posted by Johnhav430
What's fascinating about them and you know actuaries are behind it....
I stupidly bought one on a BMW 335i. Unreliable, CR most unreliable and avoid lists (then recommended for 2010 same car no changes) blah blah blah (turned out not to be the case). It was very straightforward, choices were 6/70, 6/100 (typical), 7/70, 7/100, from the date of in-service. Can be purchased up to the last day of the 4/50 warranty. Of course nothing broke except VANOS.
WHY WOULD ANYONE CHOOSE TO BUY IT DAY 1 AND FINANCE, when you can buy it the last day of the 4/50?
Now, many extended factory warranties are done say 3/54 FROM THE DAY IT'S PURCHASED. So let's say you buy it with 2 yrs. left on the factory warranty, it's written as 3/54 from that date and mileage, so essentially 2 of the 3 was already covered by the original warranty. Why are we as American consumers so easily snookered? I get that insurance has always done that, like when you insure say an engagement ring for 20k based on the appraisal, yet it's really worth 6k wholesale and that's all that insurance will pay out, they base the premium on 20 lol
If you are referring to extended warranties, Toyota I believe charges you more if you buy outside of the first 60 days.
Toys4RJill is offline
Old 11-27-17, 01:55 PM
  #32
Coleroad
Coleroad's Avatar
BMWs are not as unreliable as non-owners say, and Toyotas are not as reliable as their owners say. This in the old days was called puffing....
Exactly, people exaggerate, and others down play.
Coleroad is offline
Old 11-27-17, 02:01 PM
  #33
JDR76
JDR76's Avatar
Received 1,629 Likes on 1,037 Posts
What year is your 4Runner?
Seals and gaskets can deteriorate due to time more than just miles. If it's over 10 years or so, a leak like this wouldn't surprise me.
Edit: I see in your signature it's a 2004.
JDR76 is offline
Old 11-27-17, 02:12 PM
  #34
Johnhav430
Johnhav430's Avatar
I would think that as a general rule, Lexus and Toyota don't need them. Not that they cannot break, but that extended warranties would not be worth it. So one could just take the money out of the bank when a repair is needed...
I was just thinking about this today while in Costco, they had an extended warranty on tvs, 3 yrs. for $60. Not bad, of course, but we have a 2013 Samsung now 4 yrs. old and nothing ever went wrong....so would not be useful....
Johnhav430 is offline
Old 11-27-17, 02:13 PM
  #35
Correct. 04. 100k is should not be leaking. Not for Toyota. I get the 10 year part, but I still believe it should not be
Old 11-27-17, 03:17 PM
  #36
97-SC300
97-SC300's Avatar
Can you please stop posting this nonsense?
My brother has worked at Toyota and Lexus service for over a decade and believe me.... they leak. ALOT. All of them. EVERY MODEL TOYOTA AND LEXUS LEAKS. There. Since I don't think you got the point the first few times.
Sorry to break it to you.
97-SC300 is offline
Old 11-27-17, 03:29 PM
  #37
My0gr81
My0gr81's Avatar
QFT
Seals will leak, it's inevitable. Some will leak earlier than others, some will while you own the car or for the next owner. The ones that connect dissimilar materials will be more prone to leaking as will the ones that are exposed to extreme temp fluctuations or weather.
My0gr81 is offline
Old 11-27-17, 03:44 PM
  #38
2013FSport
2013FSport's Avatar
Received 1,536 Likes on 1,278 Posts
265,xxx mi from a 95 camry v6 1MZ-FE... No oil leaks from engine or auto trans.
Rack leaked at 155,xxx and the radiator cracked at 200,xxx. Two timing belts, oem water pump made it 21 years. Same with alternator and starter. Both hung in to about 250,xxxx mi.
ATF can leak from high up and mask itself. Find the source before labor is paid out.
2013FSport is offline
Old 11-27-17, 04:51 PM
  #39
mmarshall's Avatar
Arguably the best Camry ever built (1992-1996). An old girl friend of mine is STILL driving one LOL.
mmarshall is offline
Old 11-27-17, 06:38 PM
  #40
DaveGS4
Forum Administrator
Administrator
DaveGS4's Avatar
Received 2,321 Likes on 1,414 Posts
Some personal comments in here, let's leave those out of the conversation. If you've made your point, OK to agree to disagree and move on from this thread.
DaveGS4 is offline
Old 11-27-17, 06:40 PM
  #41
Received 3,055 Likes on 2,567 Posts
Not typical. Usually by then the cam seals especially are dried out and leaking, same for the head cover gaskets.
LeX2K is offline
Old 11-27-17, 10:38 PM
  #42
Aron9000
Aron9000's Avatar
Dude the car is 13 years old with over 100k miles on it. Its going to leak or have some sort of other mechanical issue due to the age, miles, just normal wear/tear. What makes the difference IMO on older cars is how often said problems happen, how easy they are to fix, how much $$$ OEM parts costs, are there cheaper aftermarket parts, and do said cheaper aftermarket parts actually last.
Main thing I look for when buying older vehicles, is how well were they designed from the factory for servicability and durability, and did the OEM actually spec good quality components??? Looking at some model BMW's on the forums, they are way too complex, this makes them hard to work on, and the OEM parts are brittle plastic junk that breaks after a few years because BMW wanted to save a few penny's per car.
Aron9000 is offline
Old 11-28-17, 12:42 AM
  #43
Fizzboy7
Fizzboy7's Avatar
I wouldn't be surprised there is a leak. One cannot determine longevity and durability based on mileage alone. Consider the age of the vehicle and location it has been driven (harsh elements, snow, salt, etc), Based on what the photo shows, there appears to be a fair amount of wear and tear underneath.
Hope it's not too major and resolved successfully.
Fizzboy7 is offline
Old 11-28-17, 06:33 AM
  #44
mmarshall's Avatar
Just a polite reminder...........Jill is not a "dude".
Old 11-28-17, 03:57 PM
  #45
2013FSport
2013FSport's Avatar
True...
The little 1MZ-FE was a good engine. To bad they detuned it as they did but they can't have it competing the family Badge! Things are still everywhere you look!
I picked it up at 65,xxx and it was never over heated or low or late to fluid change.... dumped the tranny fluid every two years too (32k). Like 4qts after the initial 7qt cleansing at 70,000.
Valvoline dino oil and STP as it has flat tappet cam.
Quick Reply: Now my 4Runner has an issue
