Mercedes-Benz to drop V6 engines in favor of new inline-sixes
![](https://cimg4.ibsrv.net/gimg/www.clublexus.com-vbulletin/800x450/16c968_03_d329352_1_6e46fe07357538a4ef5b850200c34c14e72a6071.jpg)
As much as some of us would like to think otherwise, building cars is a business. In order to cut down on variations and streamline production processes, Mercedes-Benz told a roundtable of journalists this week that the company would be dropping V6 engines in favor of inline-sixes. This should be good news for anyone steeped in Mercedes history, since it's a nice throwback to some of the greatest Mercedes cars of old.
The M256 inline-six was announced in fall of 2016, but we're only just seeing the engine put into production. It will first make its debut in Europe under the hood of the new CLS450. In that application, the engine will make 362 horsepower and 369 pound-feet of torque. In the Mercedes-AMG CLS53 and E53, the new 3.0-liter will make 429 horsepower and 384 pound-feet of torque.
The main reason for the change is that an inline-six can be built on the same assembly line as an inline-four, currently the most popular engine configuration in the world. It's more than simply adding on a couple of cylinders to the end of a block, but designing and building a V6 apparently is a more costly solution. Sure, a V6 can share parts with a V8, but unfortunately the automakers are building fewer and fewer V8 engines.
One question remains. What future Mercedes-Benz products will benefit from a new inline-six? Expect the engine to make its way into some of the German automaker's larger cars and SUVs, but smaller vehicles like the C-Class or GLC-Class may move to high-output four-bangers in an effort to downsize and increase fuel economy.
Using that idea, though, it also makes one wonder why more manufacturers never used a V4
....which theoretically could have been built on the same assembly line as a V6. The only one in my lifetime I can ever remember was on older Saabs, which followed the archaic, oil-burning, two-stroke, in-line three.
It's fantastic to hear that MB is going back to inline sixes, even if it's related more to production savings vs anything else. This new setup should get some good reviews from driving enthusiasts.
V4 has worse NVH unless it uses a 90 degree configuration. Exhaust routing is more difficult and thus more expensive, intake system is more expensive. 2 cylinder heads instead of one, higher cost. It looks cool in a motorcycle.
I love the inline-6 engine.
In a modern sense, the main problem with a straight 8 would be packaging. Back in the days when straight-8s were popular (primarily in 1940s/50s-era Packards and Buicks), packaging was obviously not a problem with those long, narrow hoods and engine compartments. But that was not the main reason they were dropped. That was back in the age of carburetors and inefficient fuel-delivery, and the long intake manifolds needed for the straight-eight arrangement meant that the cylinders out on the end were always running lean (more air, less gas)while the ones in the center were running rich (more gas, less air). Yes, you could use more than one carburetor to even things out a little...but at the time, with that level of technology, it simply created more problems trying to hook the linkages up together and co-ordinate their settings. Automakers, on mass-produced cars, generally didn't try that till some years later. Automakers generally stuck to V8s after that because of the packing and fuel-delivery issues.
I guess there are several factors at play. The overall shape of the complete engine package would matter to a engineering designer. The increased cost of making two cylinder heads for a V6 rather than one (plus the added valvetrain complexity and weight) would probably be significant.
I've admired how the GM guys have poked a finger in the eyes of others by reworking the plain old pushrod V8 over the years to the point that it puts out a comparable amount of horsepower while being significantly more compact than the DOHC competition.
As long as their an audible delight (BMW i6s come to mind) onboard
Super Moderator
![](http://cdn.lsxmag.com/image/2015/12/2015-12-01_23-35-20.jpg)
The engine on the right (on the stand) is a 6.0L LS1 V8. The one on the left (on the floor) is a Nissan VQ35DE 3.5L V6. Double the displacement, half the size.
Now, MB is switching back to the I6 engine by merely "adding 2 cylinders to their I4 engine". Design the (important now) I4 engine first, then quickly derive a I6 from it. It just so happens that the I6 is a much better engine design -- smoother, and less complex and with less parts -- than the 90deg V6.
That's a funny picture, the Nissan engine looks complete with all accessories the LS is mostly stripped.
Not surprising, when one figures that Chevy pushrod V8s (with a lot of modification and refinement over the years, of course), go back to 1955...an era of much greater simplicity under the hood.
Granted, I will say the clean sheet design of the LS engines is a result of GM's expertise of decades of continual improvement/refinement on that old small block chevy design.
I had a couple of 4th gen Camaros with the LS1, one hell of an engine, especially in that lightweight car(3300lbs). Made a lot more HP than advertised(my 1999 made 305rwhp, about 350 at the crank), tons of low end torque to putter around with, but man it pulled savagely from 2500rpm all the way to its 6000rpm redline, you could never catch that engine out of its powerband and it never ran out of breath near redline, these cars were savage even above 100mph.
Getting back to Benz, I must say I am glad they are going back to the inline six. Nothing beats a straight six in terms of smoothness, refinement, and sound. Tune the exhaust right and they sound amazing. Plus its one of those things that you kind of expect with a luxury car, you can buy a 10 year old $7000 used Toyota Camry with a V6 and rip low 14 second quarter mile times. Why should your $80,000 Benz have the same engine configuration and a similar performance feel??? The turbo inline six is that difference maker, that special something that makes you feel like you bought something different, something technically superior by buying a new Benz.
GM did a complete clean sheet design with the LS1 V8 in the 1997 Corvette(this engine and its smaller displacement derivatives eventually went into every GM truck, Camaro/Trans Am, full size vans and full size SUV's). The LS series V8's have nothing in common with the old small block Chevy which traces its roots back to 1955. Not a single part is compatible between the two.
Certainly great news for those, like myself, who want motor smoothness and refinement over all other things. Just about every review of BMW's once popular inline six were bursting with high praise. Would love to see such a motor filter down to Toyota, Lexus, and Honda products. Hopefully Mercedes will start a new trend here. Also refreshing to read a headline announcing a switch to something-6 instead of something-4. We've been on a downslide for about ten years as far as that goes (for better or worse).
