The 2019 Toyota Prius Is Likely Getting All-Wheel Drive
Old 11-08-18, 08:39 AM
JDR76
JDR76's Avatar
Received 1,629 Likes on 1,037 Posts
Default The 2019 Toyota Prius Is Likely Getting All-Wheel Drive
Found this from Car and Driver rather interesting.
Later this month at the Los Angeles auto show, Toyota will be releasing an updated 2019 Prius hybrid that will likely be available with all-wheel drive. The hint comes from a Toyota press release issued today saying that the 2019 Prius "performs on roads whether snowy or clear," and the accompanying image pictures a Prius driving down a snow-covered road.
All-wheel drive doesn't actually originate with this fourth-generation Prius. Since its launch in 2015, the hybrid has been offered in Japan with what Toyota calls E-Four, which is an all-wheel-drive system specifically developed for hybrid models. The E-Four setup adds a second electric motor to the rear axle that solely drives the rear wheels, and the system can switch between front- and all-wheel drive depending on driving conditions and fuel-efficiency needs. Thanks to its compact design, Toyota says, the AWD system only adds a slight weight penalty, fuel economy is no different, and luggage capacity is identical compared with the front-wheel-drive Prius.
More here: Source
JDR76 is online now
Old 11-08-18, 08:52 AM
highrev6
highrev6's Avatar
The Prime sells are strong, the Prius could use a mild refresh
highrev6 is offline
Old 11-08-18, 10:09 AM
Hoovey689
Forum Moderator
Hoovey689's Avatar
E-Four sounds like a win
Hoovey689 is offline
Old 11-08-18, 12:44 PM
riredale
riredale's Avatar
Yup, great move, and the hybrid nature of the car means it's a trivial thing to add 4wd.
I can attest that my RX450h (4wd) is a very good snow car.
riredale is offline
Old 11-08-18, 12:48 PM
plex
1UZFE/2JZGTE
plex's Avatar
Good news, that will definitely make it a stronger competitor than it already is.
plex is offline
Old 11-08-18, 01:38 PM
bagwell
bagwell's Avatar
sounds like a win-win!
good move by ToMoCo
bagwell is offline
Old 11-08-18, 02:21 PM
grabber2
grabber2's Avatar
No so for the RX400h, I was stuck in the snow few times. The engine will not start after I release the break pedal or step on the gas. The wheel just didn't even spin at all.
grabber2 is offline
Old 11-08-18, 06:32 PM
spwolf
spwolf's Avatar
Each new version of e-four improves... new one is supposed to be substantially better than last one too... although I doubt it will ever be anything close to real awd.
spwolf is offline
Old 11-08-18, 07:46 PM
Sulu
Sulu's Avatar
So I assume that the new Prius AWD will be getting the same new, more powerful E-Four system that will be in the new 2019 RAV4 Hybrid? Will the Prius be getting the new Dynamic Force engine also?
Sulu is offline
Old 11-09-18, 06:38 AM
situman
situman's Avatar
Doubt the Prius will get that powerful of an engine. I would imagine they may shove the 2.0L HSD into it.
situman is offline
Old 11-09-18, 08:55 AM
Sulu
Sulu's Avatar
The new 2.0 litre 4-cylinder engine used in the new Corolla hatchback and UX is a Dynamic Force engine.
Sulu is offline
Old 11-09-18, 07:39 PM
riredale
riredale's Avatar
I don't know about that. My RX is a 2010 model, with a specific "Snow Mode" selected on the steering wheel. It works great, with aggressive use of the rear electric motor even from a standstill.
But starting in 2016 the RX apparently dropped the Snow Mode and instead went with some sort of automatic 4wd that sensed when the front wheels were spinning. Based on that YouTube video showing a test of that function, not very impressive, but then I've never driven a late-model RX 450h in the snow. Perhaps it does as well as mine.
riredale is offline
Old 11-10-18, 03:28 PM
Received 2,772 Likes on 1,979 Posts
Hopefully they will improve its looks...
SW17LS is offline
Old 11-10-18, 04:35 PM
GFerg
Speaks French in Russian
Senior Moderator
GFerg's Avatar
Right. Forget the AWD. Are they going to fix how ugly this car looks?!
GFerg is offline
Old 11-10-18, 08:26 PM
I mean, the Prius has always been kinda weird looking, which Is part of its personality. The current generation though is just hideous.
SW17LS is offline
Quick Reply: The 2019 Toyota Prius Is Likely Getting All-Wheel Drive
