Toyota adding automatic engine shutoff and automatic park to future models
Old 06-19-19, 06:42 AM
  #46
4TehNguyen
4TehNguyen's Avatar
Don't blame it on age. Confusing controls and designs can be a problem for anyone. It took me weeks to get used to the joy-stick shifter in my own car, and its unusual patterns.
it is self evident that younger people adapt to the new tech much faster than older people.
4TehNguyen is offline
Old 06-19-19, 07:08 AM
  #47
tex2670
tex2670's Avatar
Good point. The fact that it took you weeks to get used to all the complicated and confusing controls in your Buick proves that it has nothing to do with age.
tex2670 is offline
Old 06-19-19, 11:38 AM
  #48
mmarshall's Avatar
Joy-sticks are not necessarily age-related when it comes to confusion. I've met people in their twenties who didn't like them.
mmarshall is offline
Old 06-24-19, 08:45 PM
  #49
I never knew GM has this feature already. Fords as well.
http://gmauthority.com/blog/2019/06/...ure-spotlight/
Toys4RJill is offline
Old 06-25-19, 07:40 AM
  #50
mmarshall's Avatar
I can understand why GM would have that feature, especially on their refined V6s and V8s. GM, like Toyota/Lexus, knows how to build quiet-running-engines that idle even quieter. While this would more likely affect seniors and/or those with poor hearing, even young people can sometimes forget that a GM or Lexus power plant, at idle, is still running, and not push the stop button all the way. I also notice that the stop-button on my Lacrosse, as it has worn with time, has to be pushed just so, and firmly, to get the engine to completely shut off. A green light on the button shows you the engine is running...a yellow light is the accessory-mode with the ignition off.
Old 06-25-19, 10:05 AM
  #51
geko29
Super Moderator
geko29's Avatar
That is completely unacceptable in a ~2 year old car. We have two 9+ year old cars where the start/stop buttons work identically to new, with no ambiguity as to whether they've been "pressed enough".
geko29 is offline
Old 06-25-19, 10:45 AM
  #52
mmarshall's Avatar
Perhaps I overstated it. It's not a serious issue....just barely noticeable. I'm the type of person who can notice, feel, and hear small differences (sometimes very small) in how a vehicle operates....an ability I've had since high school.
Old 06-29-19, 04:04 PM
  #53
Corey140
Corey140's Avatar
https://www.nytimes.com/2019/06/28/b...%2Fautomobiles
2 more dead in Florida, 2017 Toyota Avalon
Ms. Penney, 81, and Mr. Livingston, 88, were found dead at their home in Sarasota, Fla., poisoned by carbon monoxide, according to preliminary tests by the local medical examiner. Susan Livingston said that after the car — which had a keyless ignition — pulled into the garage attached to their house, the engine had continued to run.
Corey140 is offline
Old 06-29-19, 04:06 PM
  #54
Sad. With the tech now available that can prevent this. It’s a shame.
Old 06-29-19, 04:10 PM
  #55
Received 2,722 Likes on 1,949 Posts
Its sad, but these people did in fact kill themselves by not turning their vehicle off.
SW17LS is online now
Old 06-29-19, 04:11 PM
  #56
A bit insensitive. Could be prevented with modern tech.
Old 06-29-19, 04:17 PM
  #57
Its not insensitive, its a fact. Modern tech absolutely can prevent this, both in vehicles and in home construction. I was touring a new home complex a couple years ago and the builder installs in all their attached garages a vent that has a CO sensor on it, and when it senses high levels of CO in the garage it comes on and vents the gas outside so it doesnt leech into the home. No such building code exists this builder just took it upon themselves to come up with a feature that made their homes safer...which is great.
Where my issue comes in is the implication that somehow this is the vehicle manufacturers fault, or that this is a "byproduct" of the keyless ignition feature...which isn't fair. This is a terrible accident that is caused by the operator of a vehicle not properly turning the vehicle off. The car beeps loudly inside and outside if the door is opened and again if its closed and the key leaves the vehicle. The exact same thing can happen, and I'm sure has happened with key ignition cars also.
Its great that manufacturers are working to make cars safer in all ways, but this is not their fault.
Old 06-29-19, 04:34 PM
  #58
Its not insensitive, its a fact. Modern tech absolutely can pr.
Its insensitive in the sense that you used the words “killed themselves”. Ending ones life (not because they want to die, but because they no longer want to live) is a serious thing and to just use it in this context I don’t agree with. Anyways, you don’t have to agree with it.
Hard to post quotes on mobile, but I also have never implied that is the manufacturers fault. However, if society as a whole can make things better, we should. Manufacturers included.
Old 06-29-19, 04:37 PM
  #59
They made a mistake which led to their deaths. Better?
Not saying you implied that, but the article does.
1997Soarer
Performance & Maintenance
07-20-21 03:45 PM
Hoovey689
12-04-13 11:06 AM
rosskoss
10-31-07 06:52 PM
GFerg
11-17-05 10:21 AM
Quick Reply: Toyota adding automatic engine shutoff and automatic park to future models
