Advice: confusion on potential coolant leak
#46
OK got it. Only wondering because the owner manual makes it clear that on cold engine the level should be between "low" and "full". I'm done worrying about this for now. Sincerely appreciate everyone's help and input (and saving me $1,500..!)
#47
So have you moved on from this worry? I check my 4Runner for the brake and PS reservoir often just to be on the safe side. Just something I like to keep in mind, especially after my brakes had failed.
#48
I check the level about once every two weeks. It's still "low" but the level is completely unchanged. I need an oil change in about 1,000 miles so I'm going to ask them to drain my oil into a clear container to make sure no coolant is present. I'm driving worry free at the moment.
#50
How has your coolant issue been? We recently discovered the overflow hose was frayed, and thus we were low on coolant. Our tank overflow did not move and looked fine and the temp gauge was operating as normal...but the rad was low on coolant.
#52
One thing I learned last year, and keep in mind the Toyota cap is different (as is BMW). After doing my wife's GM water pump, I watched the coolant like a hawk, to be certain that I did not introduce any leaks from the job.
Maybe a month into it--coolant at full mark cold. Normal.
Coolant 2" above full when hot. Normal.
Next morning, coolant 2" above full when cooled overnight. HUH?
Asked around people told me air in system (wrong). So I spent $20 for a kit and bled the air (there wasn't any) figuring sweet fixed.
Same thing happened.
Did an extensive google search because what can't google solve? And found it's the job of the cap to allow coolant to return when cold (never knew this), and if that's not working, reservoir will be high and upper rad hose collapsed (this is what happened).
Not one person on a forum, nor in person, told me the above. Found some obscure article via google.
So other than finding an actual leak, looking at coolant levels can be misleading. Meaning it's not the root cause of an issue, it's a symptom or observation. My LS430 had zero coolant when I bought it, ah but this is a common tale with LS430s. Toyota has a 10 yr, interval on the pink coolant so nobody incl. dealers pay any attention.
#53
Fast forward about 8 months of me still being concerned about having a "low" level (documented in this thread) and constantly checking it, talking to an indy about it, talking to my Toyota SA about it. I needed an oil change and my Toyota SA (who I trust) was on a 2 week vacation so I took my car to a high end indy who used to work on my S5 and had done a pressure test on my LS saying there was no leak. Reminded him of the issue and explained everything again - an hour later he called and said I needed a new cap. 7k miles later my level remains at full.
Lesson: either know your stuff or know who you can trust!
#54
#55
Hey, we're not magicians! Your issue seems simple in retrospect.
I routinely replace my radiator cap and thermostat about every 5 years, or so, when I replace my coolant. It's not a lot of added cost or expense, doing it myself, and it might pay off big dividends if it prevents an overheating event.
#56
that is interesting
lexusdxb
10-30-11 06:02 PM
