Which Is Better for Your Car, Mono-tube Shocks or Twin Tube?
Former Sponsor
Mono tube shock and twin tube shock, the only two choices on your replacement, here are a few things you should consider:
For mono-tube shock, I think Mono tube shock is designed for flat circuits, it is symbolizing no aeration cause oil and gas are completely separated, Stable damping force, larger oil capacity and no restrictions in installation angles. But it also means insufficient stroke problem, stiffer ride tends, and more friction.
But for daily driver, the ride quality is the most essential for purchasing. The twin-tube can solve all the street shock absorber problems. So, I recommend twin-tube because it is not only lower production costs and easier to maintain sufficient stroke, but also low gas pressure and friction allowing for a more comfortable ride. You never know what is lying on the surface of ordinary roads. the function of the twin-tube shock absorber remains unaffected, even if the shell case is slightly damaged.
There is not much of a difference between mono-tube and twin-tube, it ‘s not said that twin-tube is better than mono-tube, just buy what you need. MaxpeedingRods Twin-Tube Damper Adjustable Coilover Suspension Kits,twin-Tube Structure creates a more comfortable ride. For Low Resiliency & Securing Sufficient Stroke.
https://www.maxpeedingrods.com/categ...coilovers.html
MaXpeedingRods, one of a few aftermarket auto parts manufacturers, accumulated over the years of experience of twin-tube, which offers comfortable shock absorber with excellent quality and technology, and affordable price.
ls430lover
01-10-14 10:02 AM
