Startup ONE says its battery prototype delivered 750-mile range
Old 01-05-22 | 01:17 PM
  #31
swajames's Avatar
swajames
Originally Posted by JDR76
He's not incorrect at all. He is saying if the way you add range is by adding batteries, the car will get heavier and more expensive. That's correct. He does not state that adding batteries is the ONLY way to add range.
It would be a different situation if he had said this: The only way to add range is to add batteries, and as you add batteries, the car will get heavier and more expensive.
It's a bit more nuanced than that. The key is energy density relative to battery mass. You can have two batteries both weighing the same, but if one delivers higher watt hour per kilo it will inevitably deliver more range, all else being equal. You will increase range if you use more efficient powertrain components or reduce mass elsewhere with no changes to the battery.
This was why Jill's original statement was incorrect (bolding mine).
I think Toyota is right. To add range, you add mass, when you add mass you add cost. I think anything is possible...but doesn't mean it will work.
But so were the attempts to clarify, bolding mine:
This is what the President of the most profitable auto maker said. Keep in mind, Toyota also has the most battery patents.
With range and affordability in mind, Toyoda said, “The more batteries you add to extend cruising range, the bigger, heavier, and more expensive a vehicle becomes."
Are you suggesting he is incorrect?
Old 01-05-22 | 01:21 PM
  #32
So do they have test logs? I'm curious about this since if EVs can get into the 1000 mile range then a 5 min charge would give good range finally.
Old 01-05-22 | 01:22 PM
  #33
JDR76's Avatar
JDR76
Perhaps I wasn't clear, but my point was that interpreting his statement to mean that Toyota thinks the only way to add range is to add batteries is not correct. The statement does not say that's the only way.
Old 01-05-22 | 01:41 PM
  #34
maybe these?
Originally Posted by LeX2K
You think everything Tesla is coming out with will never happen until it does. Then to the next.....lol I give you points for consistency.
i didn't (and don't believe ever) say 'never'. you may have seen me state that 'never' and 'aways' are overused.
it would not be a stretch to say elon musk frequently (not always) makes wildly exaggerated statements about availability, especially when it comes to things like cybertruck. yes his finance and legal team add all the disclaimers and footnotes in formal disclosures to keep him out of hot water.
Tesla buys battery cells from various suppliers and puts them in their battery packs this startup could make them in whatever form factor Tesla or other auto makers want.
interesting. i guess yes, if this startup's individual batteries were the same form factor as existing tesla's then they could be swapped out, but i suspect a major breakthrough at some point will change the setup entirely.
Old 01-05-22 | 02:11 PM
  #35
If we increase a battery electrics efficiency...we thus increase the range? how would we do that?
Old 01-05-22 | 02:13 PM
  #36
Cell internal resistance is the main one.
Old 01-05-22 | 02:14 PM
  #37
Old 01-05-22 | 03:43 PM
  #38
Och's Avatar
Och
Lets not confuse range with energy density. There are many methods of increasing a vehicles range, and most of them involve some kind of compromises. Battery energy density is completely different, and with current tech it is pretty much maxed out.
I agree. Lots of pop up claims.
Toyota has been quietly working on solid state batteries, and if anything, I have far more faith in Toyota than some start up chop shop with every red flag in the play book. Toyota, and Japanese culture in general, is very humble - they do not buy into all the hype, sensationalism and hypocrisy, they take a conservative, safe and realistic approach. They won't do anything reckless like Elon Musk, who has been warned by CEO of Panasonic (leader and one of the inventors of Lithium battery tech) about fire risks with 4680 batteries. They don't get caught in the biggest emission scandal in history like VW, and then pretend to care so much about the environment that they almost renamed themselves into Voltswagen. And they don't make ridiculous claims like Elon or this new "start up" with nothing to back it up.
I don't normally read or respond to your deranged posts, but this time I will because you are spreading straight up misinformation. The Panasonic 18650s that Tesla were using until recent have existed since before 2010, their energy density has improved by maybe 10% since then. I believe right now they are using 21700, and their increase in energy density vs 18650 is proportional to the increase in volume.
Tesla 4680 battery, if it ever happens, promises 16% energy density increase by volume.
Old 01-05-22 | 04:21 PM
  #39
F1Driver's Avatar
F1Driver
If it's not a solid state battery then it's DOA.
Old 01-05-22 | 04:24 PM
  #40
Bob04's Avatar
Bob04
Maybe I missed it, but how much $$$?
Old 01-05-22 | 07:56 PM
  #41
what do you base this on? i want Mr Fusion.
Old 01-06-22 | 10:51 AM
  #42
timmy0tool's Avatar
timmy0tool
i was just going to mention solid state, but i'm still learning about these fangled things called batteraziz!
Old 01-06-22 | 10:55 AM
  #43
Hoovey689's Avatar
Hoovey689
Hahaha great movie!
EZZ
05-08-20 01:58 PM
OldLs400
04-04-19 02:31 PM
bagwell
11-17-17 06:41 PM
diamondmit
04-02-09 03:17 PM
