Scotty Kilmer changes spark plugs on a Lexus
Was he drunk or medicated in that vid? Not trying to be mean, he indeed didn't look quite right.
![LeX2K is offline](https://www.clublexus.com/forums/images/statusicon/user_offline.gif)
Scotty!!!!! Calm done and get the job done. All Lexus DIY owners know there is a lot of STUFF to move out of the way for any maintenance item. But, thanks for the insight on plug condition as it relates to buying a used vehicle.
![f14tomcat is offline](https://www.clublexus.com/forums/images/statusicon/user_offline.gif)
![bitkahuna is offline](https://www.clublexus.com/forums/images/statusicon/user_offline.gif)
Response to bitkahuna about EV's.
It is not just because they (The EV's) are new, but also I will not be taking a trip out of town before I know there are as many charging stations as gas stations and that my EV's charging plug is addequate for what is out there or have an adapter for it.!
In addition, did you know that many States are placing a Tax on EV's to compensate for lost revenue from gasoline!!!!!
This is the biggest hidden future problem, because those taxes will go up, the more EV, are on the market and this is during this decade!
Also I need to know if in order to get to the RELAYS of the 2016 Rx 350, one needs to remove the brake fluid reservoir ?????
![wechslerl is offline](https://www.clublexus.com/forums/images/statusicon/user_offline.gif)
Looking at the Merc engine, it is a 90 degree V6, which is less than ideal, while the Lexus is a 60 degree. Are engineers forced to design such clusterpluck of an intake because of the space limitation with the 60 degree V? If so, it's little wonder many premium brands prefer inline 6 instead.
Sparks on these engines last a ton of time, not much of an issue. The annoying part about this job is taking off the intake manifold with the two bolts next to the firewall - the nasty effect is that checking compression on an actually hot engine is somewhat difficult since it takes so long to get to that point. Then again, these don't really break, so...
![Roll Eyes (Sarcastic)](https://www.clublexus.com/forums/images/smilies/rolleyes.gif)
To compensate for the lack of spark plugs, you have a timing chain at the back :P
![Lwerewolf is offline](https://www.clublexus.com/forums/images/statusicon/user_offline.gif)
He said in the video he has the omnicron, and still slightly sick, but almost recovered.
Clickbait title, but the video itself is pretty good and educational. Some of his repairs are of questionable quality and he often does a half *** job with half assed parts, but spark plug replacement is pretty straight forward. I skipped through the video, but I don't believe he mentioned about checking the gap on the plugs, which is very important, especially on turbo engines.
The best repair videos are ChrisFix youtube channel. Chris really prepares for his videos, he is very thorough, well spoken, goes into all the details, shows tools and parts required, and gets the job done right. I enjoy watching his videos even if I am not planning any such repairs myself.
![Och is offline](https://www.clublexus.com/forums/images/statusicon/user_offline.gif)
Scotty, I saw You on YouTube after you had the New variant of Covid. You said that you feel much better, all the healthy stuff to You.
Did you take Zinc 50 mg twice a day ?
And now a question for You.
In order to get to the RELAYS of 2015-2016 RX 350, do I need to remove the brake fluid reservoir that sits above it, or there is an easier way ????
Try that on the non-Pentastar v6s that followed. Intake comes off for the plugs. On the other hand, the engine is FAR more reliable even considering the switch to direct injection (practically no deposits, especially compared to its other German competitors).
Sparks on these engines last a ton of time, not much of an issue. The annoying part about this job is taking off the intake manifold with the two bolts next to the firewall - the nasty effect is that checking compression on an actually hot engine is somewhat difficult since it takes so long to get to that point. Then again, these don't really break, so...![Roll Eyes (Sarcastic)](https://www.clublexus.com/forums/images/smilies/rolleyes.gif)
![LexBob2 is online now](https://www.clublexus.com/forums/images/statusicon/user_online.gif)
Response to "You might want to post this question over on the 4th Gen RX forum. More drivers of this model will see it over there."
I did place it there but this is the problem. Most users of 4th generation are not buyers but leasers who keep the car for 3 or four years and then return it for a newer one. Those people have no clue and are not registered on this Club.
That's why I am placing it here for the people that buy the used models! Thanks, Wechslerl
