Car Care Nut on why most people need 5k mile or 6 month oil changes
#77
Not true, the leak is already there and since synth flows better it will reveal it. Sealed is sealed, doesn't matter what is used. Conventional just doesn't flow around as easily and will usually not make it as far outside of a leak point
#84
Correct, but it still reveals leaks that you then have to deal with.
#85
Well...it will. If there are no leaks and then there are leaks, then it has created a leak. Whether the leak "was there" and the oil just couldn't get through it or whatever, the reality is you have a leak where you didn't have one before, and likely would not have one if you hadn't switched to synthetic.
#87
Lol I really doubt an engine as well engineered as the 3UZFE 4.3 would start having issues. Remember those old UZ motors were indestructible, bulletproof.
You could probably run it dry for 50 miles, lol. I saw a YouTube of a Camry that went that far or farther on no oil, lol. I'd say the 4.3 V8 is more robust than a Camry 4 cyl engine.
#88
Most seals on the 3UZ are relatively easy to replace, except the cam seals.
#89
