Ok Last Time!
Ok Last Time!
NX Nitrous Express Single fogger Wet kit
IHere are the specs.
Single Fogger NX Nitrous Express EFI kit ($560 retail)
NX Fuel Pressure cut off switch
NX Electronic TPS sensor switch (uses voltage from your TPS sensor to trigger nitrous, not the lever switch)
NX Bottle warmer with safety pressure switch ($369 retail)
NX remote bottle opener (purple anodized top) ($220 retail)
NX purge kit ($105 retail)
NX blow down kit
Custom built nitrous bottle mounting bracket
Electronic switch box, triple switch box for nitrous arm, bottle warmer,
remote bottle opener, and purge. DPDT open switch, SPST arming switch,
momentary SPST purge switch.
All electronics included.
Nitrous jets 75 shot, 90 shot, 100 shot, 125 shot.
Lots of extra nitrous AN fittings.
$725 local
FYI: This is a $1200+ package.
Bridgestone Potenza S-03 Pole Position tires, only two. Used for 1800 miles before they were removed. These tires are awesome. $255 each at Tire Rack.
275/35/19 YR Speed Rated
http://f1.pg.photos.yahoo.com/ph/terrytcl/...102.jpg&.view=t
http://f1.pg.photos.yahoo.com/ph/terrytcl/...103.jpg&.view=t
http://www.tirerack.com/tires/tires....omCompare1=yes
$390
Yokohama A028 (rebadged ADVAN tires), only two tires, used for 2500 miles. These were on the fronts of my car. Tires are very grippy and low noise. 245/40/18 ZR Speed Rated, $310 each at Tire Rack.
Very rare tires.
$390
L-Sportline Body Kit, painted pearl white.
PM me or e-mail me for more details. Full kit
$1200
Rotora Big Brake kit for the GS300 / GS400 / GS430 forsale.
It might fit the SC300 / SC400 / IS300, but i'm not 100% sure
If you want info on the kit, go here:
https://www.clublexus.com/forums/sho...threadid=82466
I have put less than 1500 miles on this kit.
(less than 1500 miles):
-a set of pre-installed 4-piston calipers BLUE is what I have
-a set of 1 piece cross-drilled/slotted oversize, vented, “e-coated” discs (330mm)
-a set of high carbon steel (S45C) mounting brackets
-a set of Rotora brake pads
-a set of stainless steel braided brake lines with hardware
$950 local
NX blow down kit
$725 local
$390
Very rare tires.
$390
$1200
$950 local
