tire plugs?
I got a flat tire today, sealed it (temporarily I believe) with that "green slime" stuff I got at autozone, I haven't checked it yet as it's only been about 1 hour, I guess tomorrow I will know if it works or not. I know it's only a temp fix since that is what everyone tells me.
If I get this tire plugged it should hold up the road and stuff right [those gooey brown/black tar-gum looking thingies]? The puncture is right in the groove in the center of my tire tread, not in the sidewall.
I do not want to replace a brand new tire.
I am debating patch or plug..
http://autorepair.about.com/library/a/1a/bl028a.htm
http://www.tirerack.com/tires/tirete....jsp?techid=77
You sprayed the green stuff into the tire already? If it's one of those fix-a-flat cans that you spray in the valve stem, then you would've messed up the tire already for further usage.
Otherwise, I'd say do a plug. They usually don't have to remove the tire from the wheel to plug the hole. Heck, you can even do it yourself if you must, I know tire and wheel shops that just use plugs from AutoZone and such and plug it. I've got a plug in one of my all-season wheels and it's lasted two years without leaking.
Already got it patched today at DiscountTire.
THEY ****ED UP MY ****ING RIM WTF.
and it's NOT free. it's only free if the rim is 17 inches or smaller.
Wasn't bad though, it was 20 bucks flat.
THE IDIOTS at DiscountTire were supposed to fix the flat that was on my driver side REAR tire. but for some UNKNOWN reason, they took off my driver side FRONT, and I was like WTF?! so they put it back on and THAT is the rim they messed up!!! WTF!?!?!?!?!??!?!?!
FRUCK!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
yeah u dont have to buy a new tire, i pluged my tire on my lexus with that goooey brownish plug cause it had a big nail in it and that plug works good. Its been about four months so far with that plug in my tire and it didnt leak yet.
Bryan@Autogeek
Automotive Care & Detailing
02-19-14 03:38 PM
