MY 99 ES300 Needs some service.
I have all kinds of service lights on. Check engine, ABS, Traction control.
I would like to take an independent mechanic near naperville.
Any suggestions?
TIA.
Any suggestions?
TIA.
I bought your SC some months back. heres a pic of her as she sits now. Motor will be going in hopfully over the winter. Not as good as the volks but not to bad.
ok, So went to autozone. Pulled some code.
P1153:BBair/fuel ratio sensor circuit response malfunction
BB(bank 2 Sensor1)
Probable cause
BB1-Fuel pump, injector or pressure regulator fault
BB2-vacuum leak on engine
BB3- Faulty AF sensor Heater Circuit
BB4-Failed AF sensor
P0330: BBKnock sensor (KS) 2 circuit
probable cause
BB1-Open or short circuit condition
BB2 poor electrical connection
BB3 Faulty KS
Finally
P0441:BBEVAP system incorrect purge flow
probable cause
BB1-Block vapor canister
BB2- Vent solenoid malfunction
BB3-purge solenoid malfunction
So I was told nothing major but the knock sensor.
I should get that fixed ASAP.
So anyone that can help please post!!!!!!
Thanks in Advance
BB(bank 2 Sensor1)
Probable cause
probable cause
BB3 Faulty KS
Finally
probable cause
Thanks in Advance
MrJohnTan
Maintenance
13
02-11-04 11:17 PM
