CL Hawaii chat room
#2491
So tonight my passenger side doors both quit locking / unlocking electronically.. I noticed this when I pulled out tonight and there was an extra "click" from the doors when I put the car in drive.
Who knows how long my doors had been unlocked without me noticing. Luckily nothing got stolen! NO idea what caused this mess either
#2493
maybe its me but when i was driving down the freeway after watching the commercial i thought i saw a couple on the road but was wrong they were Mazda 3's
#2495
while cruising tumblr i found this pic of the Revision guys up in Maui. i wish the ferry was still here...
#2497
yo anyone know about soundstream amps, got a s"Soundstream Picasso 2.270 AMP", I sold my honda so I pulled off my sounds. Got it installed from Car and Audio in Nimitz. It was previously hook up on my 10" 300w JL Audio Subs. Sounded pretty good but I want to redo my sounds on my IS300. Here are the specs.
•RMS Power Range : 2x80 Watts
•Number Of Channels: 2
•Maximum Power: 270 Watts
•Low Frequency response: 10 Hz
•High Frequency Response: 35000 Hz
•Built In Crossovers: Yes
•Channel Separation: Yes
•RMS Power @ 4 ohm: 80W x 2
•RMS Power @ 2 ohm: 135W x 2
•RMS Power @ 4 ohm Mono: 270W x 1
•Fully Regulated PWM Mosfet Power Supply
•Class A/B design
•Tri-Guard Amplifier Protection
•Bi-Linear Selectable, Infinitely Variable Crossovers for Inputs and Outputs (HP/Full/LP)
•Platinum RCA and Power Inputs
•Tri-Mode Capable
•Shinny Black Hairline Anodized Heatsink
•End Caps for Professional Installation
•Variable Bass Boost
•THD: 0.10%
•S/N ratio: >95
•Damping Factor: >200
•Input Sensitivity: 200mV-8V
•Crossover Slopes: 12dB
•Low Pass Filter(Hz): 50 - 150
•High Pass Filter(Hz): 50 - 500
•Bass Boost (60Hz fixed): 0-18dB
•Phase (degree): 0-180
•Dimensions:10"(W)x2.5"(H)x14.2"(L) PCX 2.270
Let me know what you guys think, I'm hooking it up to a 300w 10" JL sub, and also on my front door speakers and rear speackers as well, I know that the IS300 comes factory with a 4 channel. Should I keep this amp or get another one?
-THANKS
•Class A/B design
•Tri-Mode Capable
•THD: 0.10%
•S/N ratio: >95
-THANKS
#2503
anyone got access to auctions? my boy just posted a pic of a 2IS that i believe is Akomplice's old 2IS. Slammed white 2IS, Vertex on stocks. its to low to be on coils so im pretty sure its bagged. Akomplice is this your old baby? Its going to be auctioned today i think.
#2504
#2505
^ My alignment is off ya, had it spec'd out when I tried to recon few weeks back. Camber is -3.4 to -4 all around and toe was just as retarded. The alignment shop ended up just pulling it off the rack and not charging me since there's no way to pass recon without fixing the camber issue.. I'm not even sure an rca kit would pass me. Should have some new rubber before Sunday cruise though.
RCA's- Recommend some places to order, and what brand? Never heard of any of these companies who manufacture them.. Times like these make me miss my S13 and the overabundance of suspension products. :/
