Just got a 93 SC
Just got a 93 SC
I just bought a garnet pearl sc 300
and I currently have rx8 rims, I like the look of it, and wanted to ask if it would match the car and if it would fit. 18x8 +50 offset, and what tires should I run with it, and if there would be some rubbing issues. If so, then I'll prolly look to get is350 stock rims.
make shure the back side of the wheel doesnt rub any suspension components with that high of an offset. what size tires are on there now? 235/40 filled the fender well okay on my old car with 18's
you got some option. go out side and test fir the wheels on your car if you got them or search in the sc section. maybe someone got some rx8 wheels on a sc in there
I will test fit them, should I go 225/40/18 on all?
it's not on any tires right now, but I want to know what kind of tires I should run
definitely wider. I had 265/18 on my rear but now I got like 245s kuz I was a dumbass and ordered the wrong ones. tryna got 280s next lol. buh maybe you should just go 240s around if they aren't staggered.
I believe they should fit. I ran 18x8 +50 offset L-Sportline rims on my old SC400 with no problems. I ran them with 245 all around. The center bore will be different, but Lexus used a 60mm bore and most other cars are a bit larger. I would get some hub rings to make them fit snug.
bryant2201
SC- 1st Gen (1992-2000)
12
05-03-11 05:37 PM
