CL of Hawaii Home of Club Lexus Hawaii
Need help! CEL, VSC/TRAF OFF light!
Old 10-24-09, 02:02 PM
Guchi_Man
Guchi_Man's Avatar
Default Need help! CEL, VSC/TRAF OFF light!
Okay, so about a little bit over a month ago i installed an injen intake for my is300. Ive been getting some intermittent CEL with the VSC/TRAC OFF lights, I've done some things suggested by other guys such as cleaning the MAF sensor, reconnecting the solenoid and attaching it to the intake tube, and resetting the battery and ECU but it keeps coming on! can anyone help me figure out whats wrong???
Old 10-26-09, 05:15 PM
PHML
Master Thread Closer!!
PHML's Avatar
did u oil up the filter on the injen intake? too much oil is not good. try cleaning the throttlebody and MAF sensor again. also make sure all connections are tight..no leaks.
Old 10-27-09, 09:05 PM
ISBU
ISBU's Avatar
check for trouble codes to make sure that the intake cause the light to come on... otherwise swap the stock intake and see if it goes away and if it does something wrong with the aftermarket intake. also check the intake tube around the maf sensor if there is a dent on it, this will also cause the cel to come on.
andy350
11-13-13 09:19 PM
Joseph7186
06-25-11 07:40 PM
lilthanh19
03-27-08 07:10 PM
sdpq
CL of Southern California
08-24-06 12:49 PM
Quick Reply: Need help! CEL, VSC/TRAF OFF light!
