CL of Hawaii Home of Club Lexus Hawaii
Program TPMS
Old 01-13-12, 12:16 AM
Deros
Deros's Avatar
Default Program TPMS
I bought a new wheel and tire package for my GX470. I went ahead and replaced the TPMS. Does anyone know a place that can program the TPMS? Lexus wants $116 to program it.
Thanks!
Old 01-14-12, 12:21 AM
Alias
Alias's Avatar
As far as I know Lexus is the only one that can do this. It does cost an arm and a leg though for a 5min job.
Old 01-21-12, 07:22 PM
RA072724
RA072724's Avatar
I went to a local alignment/tire shop to do it but the warning light wouldnt turn off so i ended up going to lexus to do it in the end.
Old 01-23-12, 03:56 AM
Deros
Deros's Avatar
I also went to the dealer in the end. It took longer than I thought. I was waiting a good 2 hrs before they were done.
I had Firestone try resetting it but the spare tire TPMS was not resetting (it was the original TPMS) with the new TPMS. I tried removing the spare, but the system was looking for the spare TPMS and would not reset. I guess it is a LEXUS thing.
What did my mom tell me; if you can't afford the maintenance don't buy the car.
Old 01-24-12, 12:15 AM
lexo98
lexo98's Avatar
If your near a Costco they might be able to help you.
Old 01-27-12, 06:55 AM
g2IS350
g2IS350's Avatar
I'm buying a set of TPMS sensors for my aftermarket wheels from a another CL member. Just wondering if have to reprogram them or can I just slap them on. And if I have to reprogram do they have to be mounted on or not. By the way the seller has a 250 and I have a 350. Thanks for any advice!
Old 01-30-12, 07:51 AM
Deros
Deros's Avatar
You will have to reprogram them. What I have read, each TPMS has a unique ID that needs to be set in the on board computer. As for the 250/350, it should not matter. As long as the optimal tire pressure of your new tires is the same as the old tire. I think it is 32PSI, with the senors going off at 29 or lower PSI.
Old 02-01-12, 11:52 AM
g2IS350
g2IS350's Avatar
Thanks for the info...will keep for future reference. The seller flaked on me !
dmk720
05-30-16 09:12 AM
Aeromotive
Wheels, Tires & Brakes Forum
11-05-14 05:03 AM
Zayarik
03-08-13 11:36 AM
nsxiboi
08-04-11 09:51 PM
RobzKar
05-07-08 11:33 AM
Quick Reply: Program TPMS
