rear suspension
Might help if you posted what kind of car and the rest of the specs on the wheels like offset and width. Also is your car lowered or any other suspension work done to it? If anything sound like your offset is pushing your wheels out further than stock and its causing them to rub the lip of the fender. Depending on how bad it is you could get away with adjusting your camber to gain a little bit of clearance. Or you could roll/shave your fenders. But it all depends on your setup and how bad they rub.
