Fender rolling-shaving?! what shop? (The Mother thread)
#153
I got mine done at Autoexplosion (body shop) in Gardena.
Where are you located?
Here are some places i would recommend:
-www.citytireonline.com (tire mounting and balancing place in South Gate that also rolls/pulls fenders)
-VIP AutoSalon in Orange
-Platinum VIP in Irwindale
You really should search these things, I've seen tons of threads with people asking this exact question
https://www.clublexus.com/forums/sea...archid=4842302
#154
I was going to need to do some rolling too when i got my alignment, luckily i dont rub. Not sure where to get a fender roller at or to rent one..
don't try a mallet and heat gun
i was doing it to my rear and brian got sick of my slow pace and grabbed it and started banging the fender and it chipped a little of my paint.. it worked but i decided not to do it.
#156
PVIP charges $75 a side. Your total will be 300 for all 4 side, but will be done professionally.
#159
I'm located in San Gabriel, CA (626 area)
I think I found my guy...
http://www.r3vlimited.com/board/show...ighlight=17x10
http://forums.vwvortex.com/zerothread?id=4807473
#161
His name is Albert. He is well known in the 240SX & Subaru scenes since 2008. He does it in the front of his garage.
Check out his work:
http://awdfitted.blogspot.com/
He does a VERY clean roll. He takes his time to get the job done right in the first time. Because once you start rolling your fender, there's no way to undo the work.
PS: He is actually fully booked until June. There's a long waiting list. I was lucky today because the other guy cancelled.
#165
I just had all 4 corners rolled by this dude. The rear was rolled and almost an inch pulled.
Check out his work:![Thumb Up](https://www.clublexus.com/forums/images/smilies/thumbsup.gif)
He does a VERY clean roll. He takes his time to get the job done right in the first time. Because once you start rolling your fender, there's no way to undo the work.![Wink](https://www.clublexus.com/forums/images/smilies/wink.gif)
Check out his work:
so we can play baseball? sure
