30,000 miles...$400.00 service. hmmmm
my car is about to reach 30,000 miles, called keyes lexus here in van nuys for est. $397.00 to be exact obviously not including tax. Is it worth it? i mean they will lend me a car since i'm doing sevice with them...hmmm..please give some thoughts... thnx...
Oh crap, I am going to take mine in for the 30k-mile service this Friday as well...
According to Edmunds, the 30k-mile service should cost $246.42 and the things that are supposed to be changed are air filter, brake fluid, cabin air filter, engine oil and oil filter. Check with your dealer to see if they are changing extra stuffs.
i thought most 30k mile service was check this check that, oh ya, and change the oil, LOL and bend you over by charging a lot of money.
my 30k service involves changing the oil, buying my k&n and blitz, changing it myself and call it a day. then when i take my car in for some godly install, have my mechanic check everything else
just my 2 cents
just my 2 cents
Really? The only thing that is required from a replacement perspective at the 30k service is the 1) oil and oil filter, 2) air filter and 3) A/C filter?
Brake fluid or tranny oil replacement is not needed? I have a IS350 btw.
why would you want to drag your transmission fluid longer than 30k?
sorry but when i changed my tranny fluid during my 30k there was plenty of crap in there.
not saying to go to the dealer for service, but the actual 30k service is supposed to include:
# Replace Engine Oil & Filter
# Replace Transmission and Differential Fluids
# Replace Coolant
# Complete Brake Fluid Flush
# Inspect and Rotate Tires
all of which you could do yourself pretty easily.
there's also tons of shops out there in socal that people recommend that won't get you like the stealership
# Replace Coolant
# Replace Coolant
# Replace Coolant
what fluids did you guys use for the tranny and diff? I'm at 75k on my 06 GS, and though I'd get that stuff changed. Also thinking of Motul brake fluid as well when i swap out my brake for the 07 4 pots.
# Replace Coolant
# Replace Coolant
the 30k service on the IS 350 is $425.00—You will replace
Engine oil and filter
Engine air filter
Inspect and/or replace the A/C filter
Replace brake fluid
Rotate and balance tires
Complete diagnostic check and undercarriage inspections with road test
*your car has the new W/T transmission fluid which want get replaced till 100k
*your car has the new Life Long Coolant which we do not replace till 100k
*your car has the new synthetic rear end gear oil which we do not replace till 90k
Thank you
Fizzboy7
07-26-10 01:37 AM
