help with fitting tires on new rims! =]
hey, i just bought a new set rims and i need help figuring out what tires to slap on them.
Car: 2007 ES350 LOWERED
Rims : 20x8.5 fronts +35 , 20x9.5 rears +40
i was told to run two different set-ups
first one 235/35/20 and 255/35/20
second one 225/35/20 and 245/35/20
i want to have as little stretch as possible and also make sure i clear my fenders. i've done the whole rim calculator thing and my rims will be pretty close to flush on my fenders. i plan on shaving or rolling my fenders as soon as i can. i was thinking of posting this in the ES350 forums, but the crowd there isnt too modder friendly i guess? =/ any input is apprieciated
If i had to pick one of those choices i would run the 225/35/20 and the 245/35/20. I myself would run 215/35/20 on the 8.5 and a 235/35/20 on the 9.5, but thats just me. Hope that helps
any other suggestions on what to run? i found out that 235/35/20 for some reason is alot more expensive.... may shy away from it. im trying to be cost effective here. i dont want to stretch because you loose out on grip. and its probably better when you accidentally run over potholes, bumps, or bump into the curb?
