Coilover Installation in the Los Angeles area
I am leaning towards getting a set of BC coils for my 2009 IS-F.
Can anyone recommend an installer in the Los Angeles area? I am in West LA, but willing to drive a bit for good shop.
If I stick with the stock ride height, do I still need an alignment after the install?
Thanks
Thanks
tommy @ Musicbox in El Monte, CA
alignment is recommended... but nut must... just make sure the installer do not drop the whole lower control arm... in essence just if you take out just a couple bolts that is really required and your car don't pull to the sides... you're probably fine without any alignment
Andre
Andre
Andre
Andre
Probably Tommy as everyone said..
if it was another car i could probably do it, i installed suspension 4 times.. but for the alignment make sure you drive around with it for awhile so it has time to settle.. if you get alignment right away your money will go to waste.
