Shop to redrill wheel barrel for TPMS
What is a good reputable shop to take the wheels to have them drill a hole to remount the TPMS so I can use the valve stems that came with the wheels?
Also, will it be a problem if they're already mounted and have tires mounted on them, aka the shop would have to take all the wheels off and remove the tires. I was planning on having it done when I get new tires anyway.
Thanks
Thanks
http://www.iforged.com/store/product...products_id=11
TPMS bracket adapters from iForged. Good alternative.
You have to dismount tires even to use adapters, so you might as well have them drilled. I think the adapters work ok, but I've heard a few stories about the sensors falling off.
Thanks for the fast replies. I called them up and got pretty good prices for the service.
For Weds Sports SA-67's do you guys think it's a good idea to drill? The shop I got the wheels from advised I should not drill since they were nice and problems could arise. The two shops mentioned in this thread said drilling is possible and they can do it.
Personally I'd like to drill so I can use the valve stems that came with them, and use the TPMS too.
tekkie
08-30-11 07:44 PM
