1jz build. HELP NEEDED
I just thought I would throw this out there. I am about to pull my 1jz for a little refresh. and I was wondering if there were some mechanically inclined people out there that can give me a hand. My plans are to get 400 whp out of this thing. I have been drifting the car for the past 2 years on a stock 1jz. works but of course I want to get some more power.
I have a good chunk of change to work with and my plans are as follows.
1. all new engine gaskets.
2. single turbo setup. (want a mid size turbo with as little lag as possible)
3. 550 cc injectors
4. boost controller (on the way) profec b spec 2
5. racing clutch
6. engine management ( haven't decided on this one)
7. front mount.
so I am going to pull the motor so that I can freshen up that main seal. cuz its leaking right now. also it will make it much easier to work on the motor.
also maybe someone can help me find all these parts.
any help appreciated.
3. 550 cc injectors
5. racing clutch
7. front mount.
I would love to help but I am still pending on pulling my ge out and replacing it with my second ge. I can snap pictures for you while I am doing it or if you want to swing by it's up to you. The down side is that the head is at the machine shop and the block has been completed. Off subject do you happen to have the stock GE headers/cat?
