The trunk was empty. I have the printout, what values do you want to see? Before or actual or both? There were a couple that were out of spec before and those got adjusted. The only one that is still slightly out of spec is Cross SAI on the front...what is that? They said that it doesn't affect tire wear.
Turns out that the rear camber arms weren't needed because they were only -1.5/-1.6 and already within spec.
Your steering axis inclination (SAI) is off because you're lowered, espcially if one side is lowered more than the other. It's not a big deal for street driven cars so don't worry too much about that. If the car tracks straight, and the tire wear is even, then you're okay.
