CL of Southern California For Southern California Lexus owners to come together.
Think I can fit? *With Pictures*
Old 06-07-11, 10:33 PM
1sWt2GS
1sWt2GS's Avatar
Default Think I can fit? *With Pictures*
About to drop on Tein CS v1 coils (it should be pretty much close dump)
I'm going to be living in this apartment during the summer but the garage parking is underground, I'm pretty sure I can make it in (like 80%) but not sure if I can get out, I will have an Admiration Lip on the car too.
What do you think?
Old 06-07-11, 11:04 PM
GS4_Fiend
GS4_Fiend's Avatar
With TEINS? I say yes.
Old 06-07-11, 11:36 PM
bADBOySC4
bADBOySC4's Avatar
looks like it'd be ok
Old 06-07-11, 11:47 PM
1sWt2GS
1sWt2GS's Avatar
how bout coming back up with a lip?
Old 06-08-11, 12:18 AM
GS4_Fiend
GS4_Fiend's Avatar
get some wood blocks.
Old 06-08-11, 12:36 AM
1sWt2GS
1sWt2GS's Avatar
^ u kno what size it should be and how I should cut them? and wood blocks would be for going back up right? i hope people in the apartment dont get mad that I'm using woodblocks to get out everytime I do haha.
Old 06-08-11, 01:22 AM
abounly
abounly's Avatar
To be honest, it doesn't look that bad. The first thing that came to my mind is your frame is gonna scratch. But if your worried about your lip you should be fine with some angles.
Try going to your future apartment and check it out first before you do anything.
Old 06-08-11, 01:24 AM
fuzzzz
fuzzzz's Avatar
You got this
Old 06-08-11, 01:25 AM
1sWt2GS
1sWt2GS's Avatar
^ wanna install the coils already they've been sitting in my trunk for the last month... haha. yeah frame may scratch and coming up i think exhaust may scrape too. im not scared coming down because i can just angle and turn in just how the mustang is (more diagonal though)
coming back up im not sure though
Originally Posted by fuzzzz
You got this
hopefully haha
Old 06-08-11, 02:28 AM
dejavu157
dejavu157's Avatar
that loots totally possible! Until ur muffler draggs on the floor if get one =P
Old 06-08-11, 02:54 AM
1sWt2GS
1sWt2GS's Avatar
^ im on stock muffies right now.
Old 06-08-11, 09:00 AM
abounly
abounly's Avatar
Well I wouldn't worry about your lip. Coming up if you can't and you get stuck you can either get wooden blocks ( waste of time unless you really really care) or gun through it like what I do :P
Old 06-08-11, 09:32 AM
mycko
mycko's Avatar
If you can make it in fine going forward, try going back out in reverse? Lol, tein cs coils still had good clearance on my car on full slam on all coils. I now have an additional inch lower with rca's. Install the coils buddy!
Old 06-08-11, 11:16 AM
1sWt2GS
1sWt2GS's Avatar
just gotta try it and see if i scrape
does any1 know the size of wood blocks i should get and how to cut / orient them? thanks!
Old 06-08-11, 11:59 AM
mycko
mycko's Avatar
I have 18" wheels , lowered all the way max with tein cs v1 along with rca's, I used 2x4 wood for everything. The 2x4 will raise you car 2 inches and it even got my car up the alignment lift with out touching my tte lip that I just had painted. FYI, my lip is about 2 inches from the ground so I just bought a long 2x4 that's about 6 ft long and cutted it in half. They go for $5-7 if I can recall. I couldn't find some small blocks of wood so I bought the long piece of wood, took it to the diy cutting board in home depot, and hand sawed it in half.
As for placement of wood, I'd place the wood under your front wheels to clear your lip and then place some under your rears if you need to clear your exhaust or subframe. I advise having a good buddy place the wood and check while you drive very slow. Anyhow, this is why I want to upgrade to air suspension! Good luck bro!
Quick Reply: Think I can fit? *With Pictures*
