CL of Southern California For Southern California Lexus owners to come together.
Barrow someones mcgard oem lug lock key?
Old 07-03-11, 11:26 AM
lunatyk
lunatyk's Avatar
Default Barrow someones mcgard oem lug lock key?
*edit* located in Long Beach
Hi, is there anyone out there with a mcgard lug key patent 4.664.000 that I would be able to barrow from? One of my lugs stripped and my lock. I don't want to waste $15-$20 on a lock when I'm replacing all of them..
I would just be coming by and taking off my lugs, not taking it home or anything.
Thanks!!
Old 07-03-11, 03:54 PM
k7q
k7q's Avatar
local tire shop should be able to remove it with a lug nut extractor/remover. i have the tool to remove it but it will have to be tuesday in la puente.
Old 07-03-11, 07:11 PM
Blk96Supra
Blk96Supra's Avatar
Where you located?
Old 07-05-11, 11:45 AM
1sWt2GS
1sWt2GS's Avatar
location location location
Old 07-06-11, 09:52 AM
lexusscturbo
lexusscturbo's Avatar
I think the Mcgard's go by color..each lockset has its own color (If you had the color code it'd help)..
the master set has a "red/blue/brown/yellow/purple/green/ect/ect key..."
You can try impact hammering it out by sliding a socket in and extracting it....
Old 07-06-11, 12:45 PM
davidwhang
davidwhang's Avatar
that patent number will not help you - lexusscturbo is correct in that it has its own color / number code that corresponds to each lock - unless you get someone w/ the exact same pattern, you will not be able to take figure it out using the patent number.
From your pictures, it is hard to judge which ones you have. I looked at the key lock set we have and it is one of three but I can't judge from your pictures.
Old 07-08-11, 03:21 PM
lunatyk
lunatyk's Avatar
Sorry for the late replies, but i'm located in Long Beach. Where would I find the color code? Only thing I read on the key is the patent number.
cowsgomoo
09-25-10 12:02 PM
kphu
10-08-08 08:21 AM
kennedy759
10-01-08 08:41 PM
UTSC300
Wheels, Tires & Brakes Forum
01-28-08 06:52 PM
Quick Reply: Barrow someones mcgard oem lug lock key?
