Experienced Retrofitter
the word "retrofit" is too vague. i can retrofit a fish tank in there if you want!
i suspect you want a projector retrofit? will you be supplying the projector? what type of projector would you like? what kind of shroud?
i did an OEM HID retrofit but did NOT use any projectors. please be more specific on what you want done.
uhm... ok...
i am currently running halogens.
i want a new set of headlights retrofitted with projectors.
the new set i want OEM used, good condition.
i have no parts, aside from new and unused AMP ballasts.
i am looking for low beam only, or a bi-xenon setup with the high beams disabled.
i would do whichever makes more economical sense.
i don't have any projectors in mind, but would like a sharp/steep cutoff with good light output.
my only objections are no halos, and no fluted shrouds where light leaks through/illuminates.
thanks.
thanks.
i ended up going with mail order.
price was better than local, turned out amazing.
http://www.ebay.com/usr/rpm-retrofit...84.m1423.l2754
tell him mapfretepeyac sent you
