The 2015 IS350C is a 2IS. It uses the same ECU for 2012-2015 in the IS350C. The same ECU was also used in the 2012-2013 IS350 Sedan.
Not sure if that makes a difference, but it's not a 3IS.
Jeff
It might. I don't want to make any promises without being positive first and again it is Frank that does the tuning so it would be him making the call on what he can and cannot do
Is there any way I can find out for sure on this tune? As stated earlier the 2015 IS 350 C is really a 2IS using the same ECU so I've been told.
Hi i have a IS 250 i am going to install a rotrex supercharged with a water methanol kit and ppe header, i already have the camshaft with the pipes exotic speed. i want to know if your ecu reflash can work on my setup. this read map sensor? if not, can you add this feature?
