New Product RR Racing ECU Tune
Jdmhoe707 (02-25-18)
#305
Congrats guys
The 2IS Supercharger its finally out
Check it out
http://www.rr-racing.com/v/mobile/pr...tid=ISXSCR2002
Check it out
#306
Guys, we are getting a 2IS in the shop next week. It has 180,000 miles on the clock. At first I wasn't keen on supercharging such a high mileage car, but now I'm thinking that if it holds up to all the intitial abuse & tuning, that will certainly be a good test of the 2GR![Smilie](https://www.clublexus.com/forums/images/smilies/smile.gif)
Rafi
Rafi
Rafi, @RRRacing
Can you elaborate on the current process for a 2IS 350 N/A flash?
When in the process is the redline limit set? For reliability I will settle for 7,000 RPM. That said what other choices are available during setup of the flash?
Car is 2012-12 production date IS-350 F-sport.
Is there any current promo code in 2019-01 to get the flash below $450?
Thanks! I'm looking to pull the trigger.
#307
Sponsor
![](https://www.clublexus.com/forums/images/ranks/rank-vendor2.gif)
No boost Bump!
Rafi, @RRRacing
Rafi, @RRRacing
Not sure if we have any deals right now, please email us at service@rr-racing.com and we’ll check.
Rafi
#308
If you would like a custom rev limit, let us know when you send us the ID file for your ECU.
Rafi
Bump - were you able to do anything with the transmission lag?
My data logging of trans and engine shows a consistent element of TCU data lagging behind ECU data. Which begs the question are the two on the same network node and able to transfer data at the same rate?
Can you elaborate on any changes applicable to the AWD 3IS as their A760H six speed doesn't have this lag problem when manually shifted.
Second question about the 2IS; can you publish the AFR? The car reports it as 12.0:1 while it likely makes more power at say ~13.1:1. I ask as I thought I saw it once with a dyno report but can't find it as of this writing.
As a reminder I have your tune. Thanks!
#309
Sponsor
These cars actually do not make more power at leaner AFR.
Rafi
__________________
We Engineer Track Proven Upgrades For Your Lexus!
SUPERCHARGERS : ECU TUNING : SUSPENSION : EXHAUST : PPE MASTER DEALER
Nigel-JDMParts
IS F (2008-2014)
262
05-24-14 02:53 PM
