Lexion Carplay & Android Auto Display for all Lexus models
#256
Lexus. So it will switch to Lexus OS but I can’t choose any functions on the screen. The moving map works but touchscreen doesn’t work, trackpad doesn’t work and I can’t access any stock Lexus functions.
Also, audio quality is seriously gutted through this system. I have a JL 12 hooked up and it was sounding fine before. Now after install it barely makes a sound.
I’m not real happy so far…
mxpx148 (07-23-21)
#258
I have no idea why it is stuck on the navigation screen or your sound is bad. I have neither of these issues.
I have Lexus navigation and though I rarely use it, it does work fine. My sound is fine as well.
Jazzrock (07-23-21)
#260
Resetting didn't work...
So the audio issue seems to be that my aftermarket sub won't turn on now after install. It is wired (speaker level inputs and remote turn on) to the factory amp. Does this system bypass the amp?
Also, made a bit of headway with the Lexus OS freezing on the nav screen. If I unplug the jog mouse connector from thee Lexion harness, and plug it back into the stock harness, I can use the Lexus OS perfectly. When I plug it back in I cannot access it at all. I am wondering if the harness is bad...
#261
I am thinking maybe there is an issue with the harness. I unplugged he unit and went back to stock, my subwoofer worked again and there were no issues. I plugged the Lexion unit back in, cannot access Lexus OS, the jog mouse doesn't work outside of the Lexion OS, and my subwoofer doesn't work.
#263
Installed today. Spent about 20 minutes with one of the managers of the shop. We both figured it out together. Works great. Sound is
excellent. Steering wheel buttons work fine. The tech returned and said to hold Menu to return to the Lexus menu, which saved a few
steps. I'll play with it more tomorrow. The larger screen is amazing! A CL member is coming here tomorrow to check it out. Three thumbs up!ztrane@earthlink.net
#264
Originally Posted by dappy9
How much did you pay? I live in norcal so if you can recommend a good shop for me I would appreciate it
#265
update video, so after a solid month of testing with two IS350's (2013 and 2016) its safe to say we are both very happy with the unit!
its pretty much as 'OEM' as an aftermarket will get tbh.
https://youtu.be/4MFUpbbPxGw
#269
Is wireless carplay built into the unit or via USB dongle?
How many USB inputs does this unit have? 1 or 2?
Also is there a backup camera trigger accessory wire? I know This unit works with OEM backup camera, but that's not why I am asking. I have a front bumper camera as well connected to a switch (beatsonic front/rear cam interface) and want to be sure it has the rear camera trigger wire that I will need to tap into.
#270
whoismiked (07-27-21)
