Lexion Carplay & Android Auto Display for all Lexus models
#526
Couple questions. I know the Lexion unit takes about 20 seconds, but what about the factory side? Can I turn on the car and have it work as quickly as it did when the Lexion wasn't installed, or is that 20 seconds also?
Jazzrock (01-24-22)
#530
#531
Hi,
Been following this a while. Also the 4x4 thread.
Some remarks:
- Lexion is a worthless company
- Lexion uses the units from Binarytec??
- Ryan Chan at sale02@binarytec.cn seems to be helpful
- Binarytec has 2 units in the shop
https://www.aliexpress.com/item/1005...000069911710.4
and
https://www.aliexpress.com/item/1005...2ce970fdPKcYVC
- Both have an extra cable to control the mouse/jog/wheel
- Both use the same chipset
- Both have Wireless Carplay
- Both support 360 cam.
Lexion states factory 360 cams.
Binarytec just claims 360 support
Lexion states android 10.
Binarytec claims an android 7 unit
Lexion does not use an external mic.
Binaryytec shows an external mic but states a Built-in Speaker / Microphone
Binarytec claimes 4G.
Lexion screen is 1920*720
Binarytec screen is 1920*1080
No dealer mentiones split screen function?
Is that a standaard Android 7+ feature?
The Binarytec systems seems to have slightly beter specs.
It seems to have better support.
In Europe wit VAT and import Tax the Binarytec unit cheaper.
Is the Binarytec unit the one you all recommend?
Regards,
Armand
Some remarks:
and
Regards,
Armand
#532
I’m working with Reyn from binary tek. His email is sale02@binarytek.cn
been trying to reach lexion but apparently the sales manager (?) is in the hospital ? I’m working with Reyn to replace a unit that was incorrectly spec’d for me (I don’t have navigation in my RCF).
#533
I recently purchased a 12.3" unit direct from Reyn. Here's a link to some pics and a short video:
2014 ES300h BinaryTek/Lexion 12.3"
I could only load a one-minute video on imgur, so I had to be selective on when it started/stopped to get the most useful info up--but that's why it starts and stops so abruptly.
I'd been on the fence with upgrading my 2014 ES300h with a CarPlay unit for a few months now. Lexion's units seemed to be the best performing, but the biggest hassle to purchase. I had originally reached out to 4x4shop because my model wasn't on their compatibility list--they said it wouldn't work (I'm not sure why that's the case). I reached out to Reyn to ask about compatibility based on this thread's feedback, and he directed me to the Lexion rep from Korea. After a while Reyn got back to me and said the rep is in the hospital and so I arranged to buy direct from him (Binary Tek). Once that communication started this was quick and easy--he showed me clips of this 12.3" unit (all the hardware is in the screen) and I sent him some pics of my car so he knew exactly which cable harness to send. I received the unit about a week after I ordered (I'm in the US).
As with other units, it doesn't come with directions, though the plugs are reasonably well labeled, and they all seem to be unique (you can't fit a monitor cable into a power jack, etc). There will be excess plugs though on the harness that you don't use. I used the beat sonic video found on youtube to guide me through removing the trim and radio. A couple differences though: (1) You will NOT need to remove the glove compartment for the Binary Tek install (I fed my USB plugs down the side near the glove box, but that doesn't require glove box removal) (2) You will need to pull up the center console (just the top) in order to access the joy stick control (make sure you use the harness plug labeled "joy stick" and not "touch pad")--This comes up pretty easy with trim removal (start from the side closest to the radio)--it's clips only--but I didn't see any videos on pulling it up.
Also--the mic didn't work for my right off the bat because I didn't have it plugged in properly--the Binary Tek unit has a male and female mic plug. If you're using the OEM mic (which I wanted to do) then plug these two plugs together. Reyn had to tell me that. I'd had some issues along the way with install, and he's been great with communication/pictures to show me what it should look like.
It came with an external mic and GPS receiver--I didn't bother installing either of them.
Earlier in this thread, someone posted a password for advanced settings. It's still the same: 8868123
You will need this password to get your backup camera working--it's set to a different camera mode as default, but it's easy to change with that password (thanks Lutsiv5703 for posting it).
ReynChan (05-01-22)
#534
I recently purchased the unit from Lexion. Joon on Whatsapp was pretty much MIA from day 1. The order took a long time to process.
When I finally receive it, my unit comes in 1 piece (the display and processing box are intergrated). One user on Lexion's youtube said they receive the same product. Perhaps they no longer makes it as 2 separated pieces? The advertisement for "not overheating" doesn't seem to hold.
I did get Google Map on the unit crashed when it was very hot out (100F).
I decided to install it anyway, only for the backup camera doesn't work... I already connected the yellow wires labeled camera together, and change camera type in advanced setting to CVBS. When in reverse, the display just shows a black screen. I suspect my harness has some issues but of course, Lexion doesn't reply to email nor Whatsapp. Already emailed Reyn but still haven't heard back![Frown](https://www.clublexus.com/forums/images/smilies/frown.gif)
I will wait until the end of the week to file a dispute. Really wanted to get it to work, but without backup camera it's a bit painful (RC350). If anyone has any contacts that I can reach Reyn for potentially replacing the harness, I would really appreciate it!
#535
The passcode to get into advanced settings is 8868123
Sorry, I don't have my car with me at the moment to guide you through exactly which settings to go to, but if I recall it was fairly intuitive once I entered the code. This is assuming you have the OEM backup camera and not an aftermarket version.
EDIT: and Reyn is the only person there who I have had successful contact with (via e-mail and not whatsapp), but he was very helpful in dialing in settings after install.
#536
Thank you for the advice! I'm aware of the advanced setting change but that didn't work.
Did your come in 2 pieces or intergrated? I probably will end up returning it if possible and buy direct from binarytek.
#537
#539
#540
