New Product SS3 Fog Light Kit for the 2014-2015 Lexus IS 250! | Diode Dynamics
Former Sponsor
Our SS3 LED Fog Light Kits are now available for the 2014-2015 Lexus IS 250! These bolt-on kits allow you to replace your factory fog lamps with a pair of SS3 LED Pods. Featuring higher output intensity than any other 3” LED pod on the market, our SS3 LED pods have been designed for maximum light output, with custom-engineered TIR optics shining in highly functional beam patterns, all in a compact, durable package.
Focused: Most LED pods on the market, even certain premium options, use outdated technology like reflectors or simple lenses that lose light internally and to glare. By comparison, our custom-engineered total internal reflection (TIR) optic in the SS3 collects all of the light from the LED chips, drastically reducing wasted light and improving total efficiency.
While these outdated optics lose up to 10% of the light output shining through an outer lens, the SS3’s custom-molded TIR optic functions as both the optic and the main lens, dramatically increasing the amount of usable light output.
![SS3 Fog Light Kit for the 2014-2015 Lexus IS 250! | Diode Dynamics-7nwvmlf.jpg](https://www.clublexus.com/forums/attachments/cl-vendor-products-for-3is/485954d1683149362t-ss3-fog-light-kit-for-the-2014-2015-lexus-is-250-diode-dynamics-7nwvmlf.jpg)
Functional Output: All SS3 LED Pod beam pattern options were designed with optical simulation modeling, to shape the light output in a highly-functional beam pattern. Making it a perfect option for your factory fog location! We offer these kits in two SAE-compliant optics:
SAE Driving optic is designed to supplement your high beams, but it’s great for improving general illumination as well. Rather than a typical "spot" pattern, the Stage Series Driving pattern shines in an 18x8 degree spread, providing just enough width to completely light up the road ahead at high speeds.
SAE Fog optic provides an extremely wide field of illumination, with high-intensity light output over an entire 80-degree spread. It serves as a great upgrade for any factory foglamp, and will fully illuminate the area in front of your vehicle. Choose your output color of 6000K cool white or 3000K selective yellow, which is popular for cutting through inclement weather.
*When installed as a pair and aimed in accordance with your state's regulations, the Driving White pattern meets SAE J581 standard as a Driving/Auxiliary High Beam Light, and the Fog pattern meets SAE J583 standard as a Foglamp, for legal on-road use. Please check your local laws and regulations for aiming, installation, and applicability.
![SS3 Fog Light Kit for the 2014-2015 Lexus IS 250! | Diode Dynamics-wyfb1qh.jpg](https://www.clublexus.com/forums/attachments/cl-vendor-products-for-3is/485955d1683149362t-ss3-fog-light-kit-for-the-2014-2015-lexus-is-250-diode-dynamics-wyfb1qh.jpg)
Backlight Functionality. The Stage Series 3" LED Pod is now available with a distinctive backlight, in a brilliant amber color. This integrated backlight gives you an additional accent light, along with the main beam. The SS3's backlight fully illuminates the TIR optic, providing a more unique and modern look than the small indicator LEDs found in other products. To power the backlight, use the included harness to tap your desired vehicle function.
![SS3 Fog Light Kit for the 2014-2015 Lexus IS 250! | Diode Dynamics-et90tjn.jpg](https://www.clublexus.com/forums/attachments/cl-vendor-products-for-3is/485956d1683149362t-ss3-fog-light-kit-for-the-2014-2015-lexus-is-250-diode-dynamics-et90tjn.jpg)
White or Yellow: Our SS3 LED Pods are available in your choice of 6000K cool white or 3000K selective yellow. The white is a 6000K color temperature, which is a true white output, without any blue, and is a perfect match for most OEM LED lights. The selective yellow is a 3000K color temperature, great for high contrast in poor weather or a totally unique look on the road.
![SS3 Fog Light Kit for the 2014-2015 Lexus IS 250! | Diode Dynamics-bs4n3y4.jpg](https://www.clublexus.com/forums/attachments/cl-vendor-products-for-3is/485957d1683149362t-ss3-fog-light-kit-for-the-2014-2015-lexus-is-250-diode-dynamics-bs4n3y4.jpg)
Sport/Pro/Max: Stage Series LED Pods are available at three different power levels. All options use high-intensity LED emitters, and TIR optics for unmatched focus and overall output. The sport model uses high-intensity LEDs and is the best bang for your buck you’ll find. The Pro steps things up in a big way, with double the total power. Finally, the Max model is designed with cutting-edge automotive emitters, both for high power and extreme intensity. This brand new technology comes at a cost, but if you’re looking for the absolute best in lighting performance, the SS3 Max is the answer.
![SS3 Fog Light Kit for the 2014-2015 Lexus IS 250! | Diode Dynamics-4qd6ttd.jpg](https://www.clublexus.com/forums/attachments/cl-vendor-products-for-3is/485958d1683149362t-ss3-fog-light-kit-for-the-2014-2015-lexus-is-250-diode-dynamics-4qd6ttd.jpg)
Plug-and-Play Installation: These kits feature bolt-on installation, meaning they require no cutting, drilling, or permanent modification! Our SS3 Fog Light Kit for the 2014-2015 Lexus IS 250 includes a custom-engineered bracket and bezel for a clean, factory-style appearance.
Each kit will include:
![SS3 Fog Light Kit for the 2014-2015 Lexus IS 250! | Diode Dynamics-xdxytdj.jpg](https://www.clublexus.com/forums/attachments/cl-vendor-products-for-3is/485959d1683149362t-ss3-fog-light-kit-for-the-2014-2015-lexus-is-250-diode-dynamics-xdxytdj.jpg)
Proven Reliability: Our SS3 LED Pods have been extensively tested for long-term operation from -40 to 185 degrees F, along with vibration, moisture intrusion, and corrosion testing. All of these tests are completed to SAE standards, just like OEM components!
If you have any questions, please don't hesitate to post, PM, or email contact@diodedynamics.com.
PM us for the free-shipping code (U.S. forum members only)
Thanks for looking,
John C.
Diode Dynamics
- Two (2) SS3 3” Standard LED Pods
- Two (2) H11 DT Adapters
- Mounting brackets and hardware
Thanks for looking,
John C.
Diode Dynamics
Former Sponsor
![SS3 Fog Light Kit for the 2014-2015 Lexus IS 250! | Diode Dynamics-0m1vhyp.jpg](https://www.clublexus.com/forums/attachments/cl-vendor-products-for-3is/504147d1683210751t-ss3-fog-light-kit-for-the-2014-2015-lexus-is-250-diode-dynamics-0m1vhyp.jpg)
Don't miss your chance to save 15% off your entire order of lighting upgrades!
Coupon Code: USA22
Plus, get FREE shipping when you spend $300! HURRY, this sale ends TONIGHT!
Click HERE to Shop!
Sale ends 11:59 p.m. CST | Friday, 06/3/2022.
Note: Items on pre-order are exempt from the sale.
Former Sponsor
Attachment 485687
THE CLOCK IS TICKING!
Hurry! There are ONLY 3 DAYS LEFT to save on your favorite LED lighting products from Diode Dynamics.
Click HERE to shop!
Click HERE to shop!
John C.
Diode Dynamics
Sale ends 11:59 p.m. CST on Friday, 7/8/2022. Cannot be combined with other coupon codes.
Former Sponsor
![SS3 Fog Light Kit for the 2014-2015 Lexus IS 250! | Diode Dynamics-p1g4zmg.jpg](https://www.clublexus.com/forums/attachments/cl-vendor-products-for-3is/504145d1683210751t-ss3-fog-light-kit-for-the-2014-2015-lexus-is-250-diode-dynamics-p1g4zmg.jpg)
ALERT: LAST CHANCE TO SAVE 15% OFF!!!
COUPON CODE:
JULY4
Plus, all orders over $300 will receive free US shipping!
Don’t wait...this sale ends TONIGHT!
Click HERE to Shop!
John C.
Diode Dynamics
Sale ends 11:59 p.m. CST on Friday, 7/8/2021. Cannot be combined with other coupon codes.
Former Sponsor
Attachment 485570
The clock is ticking!
Click HERE to shop!
Click HERE to shop!
John C.
Diode Dynamics
Sale ends 11:59 p.m. CST on Friday, 9/9/2022. Cannot be combined with other coupon codes.
Former Sponsor
➡ 20% OFF Sitewide
➡ 30% OFF Stage Series Single-Row Lightbars
➡ 15% OFF Elite Series Headlights
➡ Plus, orders over $300 receive free US shipping!
Excluded Products:
➡ Hitch Mount LED Pods (Includes free US shipping)
John C.
Diode Dynamics
Sale ends at 11:59 p.m. CST on Tuesday, 11/29/2022. Cannot be combined with other coupon codes.
Former Sponsor
⌛THE CLOCK IS TICKING... ⌛
NOW is your chance to SAVE up to 15% sitewide on your favorite Diode Dynamics LED lighting products.
➡ 15% OFF Stage Series Rock Lights & HitchMount LED Pods
➡ 10% OFF Elite Series JL/JT Headlights
➡ Free US Shipping on any order over $300!
CLICK HERE TO SHOP NOW
Attachment 485329
Did you know?
You can find all of the products we offer for your vehicle using our vehicle finder tool! Simply enter the year, make, and model.
SALE EXPIRES 11:59 P.M. MONDAY, MARCH 13TH, 2023.
Discounts cannot be combined with other offers or any previous orders. Excludes items with pre-order status.
Attachment 485329
Did you know?
Former Sponsor
[MEDIA=youtube]utD2YXqp3Yg[/MEDIA]
🚨 Our Memorial Day Sale is LIVE!!! 🚨
➡ Up to 15% OFF Sitewide
➡ 10% OFF JL/JT Elite Series Headlights
➡ Free US Shipping on any orders over $300!
Excluded: F150 Elite Series Headlights, and F150 Elite Series Fog Lights
John C.
Diode Dynamics
Hours: Monday-Friday 10 a.m. - 5 p.m.
Email: contact@diodedynamics.com
Phone: 314-205-3033
Sale ends 11:59 p.m. CST on Friday, 6/2/2023. Cannot be combined with other coupon codes.
Former Sponsor
⏳ WARNING! TOMORROW IS THE LAST DAY TO SAVE! ⏳[/CENTER]
➡ Up to 15% OFF All Lighting Upgrades
➡ FREE US Shipping on any order over $300!
No coupon code is required.
Click HERE to shop lighting upgrades for your ride!
🚨 Sale ends 11:59 p.m. CST on Friday, 06/02/2023. Cannot be combined with other coupon code 🚨
John C.
Diode Dynamics
Phone: 314-205-3033
Former Sponsor
It's our LAST SALE of the summer!
Save BIG on premium US-assembled lighting sitewide!
The time to upgrade is NOW!
➡ 20% OFF Single Row Stage Series Lightbars
➡ 10% OFF Sitewide
➡ FREE US Shipping on orders over $300!
The sale ends Friday, 9/8.
*Exclusions apply. While supplies last.*
CLICK HERE TO SHOP YOUR RIDE AND SAVE!
Did you know?
You can find all of the products we offer for your vehicle using our vehicle finder tool on our website! Simply enter the year, make, and model and all options will appear.
![](https://i.imgur.com/WEWWfNf.jpg)
Did you know?
Diode Dynamics
Club Lexus Vendor Marketplace
22
09-01-23 02:45 PM
Diode Dynamics
12
08-31-23 01:52 PM
Hatchy400
SC- 1st Gen (1992-2000)
30
05-15-14 07:07 AM
