New CL Vendor R1 Concepts| High Carbon Alloy Geomet Rotors & Brake Pads!
Sponsor
![](https://www.clublexus.com/forums/images/ranks/rank-vendor2.gif)
Unfortunately we still don't have the front rotors available just yet. They should be available probably by the end of the year or beginning of the new year.
__________________
Kevin- Sales Representative
R1 Concepts Inc.- Performance Brake Parts
Kevin@r1concepts.com
888-712-6623 Ext. 7022
Sponsor
Just got an update and these rotors will be arriving the second week of January but we only have a limited amount of pieces available. We''ll be receiving more from our manufacture within in the next 2-3 months.
__________________
Sweet! Will you be offering the same customization options? Slotted/drilled etc
Sponsor
Yes, we'll be offering these in slotted, drilled, or drilled & slotted. Rotors just arrived and pricing will be up this week!
__________________
Sponsor
2-piece front rotors now available! Pricing is listed on the 1st page.
__________________
Sponsor
These rotors are equivalent to the OEM 2-Piece rotors. A few differences is that these have a black aluminum hat, these also have a Geomet coating applied on the rotor to prevent it from rusting, and finally are fine-turned instead of double disc grinding. Here's a better explanation of "fine-turned" from our thread:
"The castings are sent to our state of the art machining facilities, where each rotor is machined to the tightest tolerances available in the market today. We can guarantee specifications of .010mm disc thickness variation (DTV) and .050mm maximum lateral runout. Though in practice, we regularly achieve .007mm DTV and .025mm maximum lateral runout. Then, the rotors are fine-turned to a maximum of 1.6 RMS. The objective of these strict tolerances is to create the smoothest possible finish, which improves initial break-in due to the increased contact between the pad and the rotor."
Pricing and the actual picture of the rotor is listed on the 1st page as stated in the post. These are available in slotted only, drilled only, or drilled & slotted as well. I'll post the rotors in this reply:
![](https://preview.ibb.co/exp72R/GS350_2.jpg)
![](https://preview.ibb.co/kAarU6/GS350_3.jpg)
__________________
Sponsor
The brake noise will be coming from the brake pads itself since rotors do not make brake noise. Depending on the pad compound that's on the vehicle will determine if the pads will create any type of brake noise or not.
__________________
Sponsor
Unfortunately do we not offer 2-Piece rotors to fit with the OEM calipers.
__________________
