New CL Vendor R1 Concepts| High Carbon Alloy Geomet Rotors & Brake Pads!
#121
Sponsor
PM if you have any questions!
__________________
Kevin- Sales Representative
R1 Concepts Inc.- Performance Brake Parts
Kevin@r1concepts.com
888-712-6623 Ext. 7022
#124
Sponsor
Bump for the new month!
__________________
R1Concepts (12-09-20)
#126
Sponsor
End of the year promo for 35% until the 31st!
__________________
#129
Sponsor
Right now I'm offering 30% off for Black Friday/Cyber Monday deal till the end of the Month. As for December, probably towards Christmas.
__________________
#130
#131
Sponsor
Depends on what parts you're specifically looking at on the website. I'll send you a PM.
__________________
#132
Want to purchase it. Any in stock? If not do you know when
Any eta on these? I have a 2018 Lexus g350 d sport AWD. It's 14 inch front and 12.2 inch back rotors. I'm looking for a complete set.
R1 Concepts- High Carbon Alloy Geomet Rotors!
We're happy to introduce to you all our new High Carbon Alloy Geomet rotors! These rotors are a new and improved version of our "Premier Series" rotors. Manufactured for european and heavy vehicles, our High Carbon iron formulations enhances noise dampening characteristics, while providing high strength, and increased thermal conductivity compared to standard discs, which increases durability. Each rotors is engineered to match the OE vane configuration, including OE split-core technology to ensure proper and maximum heat dissipation. Additionally, all cores are dipped with a specifically formulated paint in order to provide a smoother finish inside the vane structure. The smooth finish will improve air flow as well as reduce the amount of machining required in order to properly balance the finished rotor during the mill-balancing process.
Geomet Finish
After all the machining processes are completed, each rotor passes a 100% electronic inspection station that measures over 20 attributes to ensure that each rotor meets OE specifications. This further guarantees that each and every rotor delivered to you is trouble free. Finally, we apply a genuine GEOMET finish throughout the entire part, which promises to deliver superior corrosion protection. The GEOMET coating is processed dry, shipped dry, and ready to install without any additional preparation.
-Ready to install- No additional preparation needed. Saves time and money during installation process.
-Superior Corrosion Protection- Provides excellent cyclic corrosion performance when tested according to automotive manufacture's test methods incorporating heat, salt spray (withstands 400 hours), and humidity (SAE J2334, GMW 14872, Ford CEPT: 00.00-L-467, Asian CCT).
-Environmentally Friendly: Meets the following regulations: Environmental Protection Agency (EPA), Chrysler CS-9003, General Motors GMW 3059, Ford WSS-M99P9999-A1 (Hex 9), the EU Directives on End of Life Vehicles (ELV) and Electrical Equipment (RoHS).
Fine-Turned
The castings are sent to our state of the art machining facilities, where each rotor is machined to the tightest tolerances available in the market today. We can guarantee specifications of .010mm disc thickness variation (DTV) and .050mm maximum lateral runout. Though in practice, we regularly achiece .007mm DTV and .025mm maximum lateral runout. Then, the rotors are fine-turned to a maximum of 1.6 RMS. The objective of these strict tolerances is to create the smoothest possible finish, which improves initial break-in due to the increased contact between the pad and the rotor.
2013-2018 GS350 AWD & RWD Without F Sport
FT/RR CARBON ALLOY OEM GEOMET ROTORS: $225 SHIPPED
FT/RR CARBON ALLOY SLOTTED GEOMET ROTORS: $330 SHIPPED
FT/RR CARBON ALLOY DRILLED & SLOTTED GEOMET ROTORS: $350 SHIPPED
FT/RR CARBON ALLOY DRILLED GEOMET ROTORS: $340 SHIPPED
FRONT CARBON ALLOY OEM GEOMET ROTORS: $145 SHIPPED
FRONT CARBON ALLOY SLOTTED GEOMET ROTORS: $210 SHIPPED
FRONT CARBON ALLOY DRILLED & SLOTTED GEOMET ROTORS: $220 SHIPPED
FRONT CARBON ALLOY DRILLED GEOMET ROTORS: $220 SHIPPED
2013-2018 GS350 RWD F Sport (1-Piece Full Cast Front Rotors)
FT/RR CARBON ALLOY SLOTTED GEOMET ROTORS: $600 SHIPPED
don you have any in stock? 2018 Lexus f sport AWD? I want to purchase it for my car.
FT/RR CARBON ALLOY DRILLED & SLOTTED GEOMET ROTORS: $620 SHIPPED
FRONT CARBON ALLOY SLOTTED GEOMET ROTORS: $480 SHIPPED
FRONT CARBON ALLOY DRILLED & SLOTTED GEOMET ROTORS: $490 SHIPPED
Geomet Finish
Fine-Turned
#133
I sent yo PM. Please answer me. GS 350 RWD F SPORT. 14" Rotors:
Are your FRONT CARBON ALLOY SLOTTED GEOMET ROTORS compatibles with my car? Can you explain the benefit of my OEM 2 piece and Yours 1 piece Please?
R1Concepts (02-10-22)
R1Concepts
CL Vendor Products for RC
85
01-14-21 12:16 PM
R1Concepts
CL Vendor Products for RC-F
106
01-14-21 12:15 PM
R1Concepts
Club Lexus Vendor Marketplace
172
01-14-21 12:13 PM
R1Concepts
CL Vendor Products for 2IS
88
01-14-21 12:11 PM
R1Concepts
CL Vendor Products for 3IS
96
01-14-21 12:10 PM
