CL Vendor Products for IS-F New product details, group buys and more, specifically for the IS-F model from CL Vendors
New Product Front F Bushing offering and eye opening video inside.
Old 11-25-13, 05:58 PM
  #151
ISFpat
ISFpat's Avatar
noise you get with wide wheels on a lowered car and the wheel scrubs the fender liner on low speed turns.
Old 11-25-13, 06:41 PM
  #152
yjk1975
yjk1975's Avatar
I'm lowered on BC coils and run 19x9 +30 and 19x10 +40. Maybe I'm not low or wide enough. I'll have to listen for it.
Old 11-25-13, 09:37 PM
  #153
lobuxracer
Tech Info Resource
lobuxracer's Avatar
Received 4,020 Likes on 2,435 Posts
No, not this at all. The car, as delivered from Lexus, will jump slightly at parking lot speeds with a high steering angle - it's a lot like driving over wet leaves while turning, but without any wet or leaves. ALL 2IS do this, not just the F. I noticed it on my 350. I figured it was tire scrub, but my Supra with significantly wider tires has never done this or made this sound.
If your tires rub anywhere on the car, you should modify your setup so they don't. Rubbing is nothing but bad. Accepting it as a cost for fashion is something I will not do, and it is very unwise from a risk management perspective. Slicing a tire and having it shred at speed because you want to look good could have very serious negative consequences to your personal appearance.
Old 11-25-13, 10:58 PM
  #154
ISFpat
ISFpat's Avatar
The tire is rubbing plastic. Tire > plastic in terms of what wins the shredding battle. If it was hitting metal that would be a different story and I would definitely modify it. It seems however many IS-F owners are having this rubbing issue with wider wheels while driving at low speeds.. thats just because of how much fender well space Lexus gave us and it isn't very much at that.
The issue you described also seems to have went away with the new bushings so thats a good thing that I didn't realize until you mentioned it.
Old 11-26-13, 01:18 PM
  #155
FIGS
The Maker
FIGS's Avatar
Originally Posted by WylieKylie
Hey Figs, would you be interested in starting a core/replacement type program? ie, we buy the brackets with the new bushings installed, and you refund a core charge when we return a good set of brackets?
Just an idea
we can do this its just a matter of buying the factory bushings for $50. Just contact me to make arrangements.
__________________
Redefining Lexus Aftermarket Parts Since 2001
-- We are your Lexus suspension experts--
BCR - KW - PENSKE - OHLINS - HKS - GREDDY - STANCEPARTS
Links - Arms - SuperPro Poly Bushings - Solid Bearing Conversions - Motor Mounts
RB BBK's and 2P Rotors, G-Loc pads, Radium Fuel Systems
Custom Fabrication Design and Machining - Industrial 3D Printing - Laser Cutting
2018 USTCC Sportsman Class Champions - 2018 NASA ST5 National Champions
Old 11-26-13, 09:16 PM
  #156
stick
stick's Avatar
^^^^That is a good idea. I'd rather buy them already installed in brackets.
Old 11-27-13, 08:08 AM
  #157
zojirushi
zojirushi's Avatar
Will this result in a plug and play installation? Is an alignment recommended after installing it if I purchase the bushing preinstalled into the bracket? Thanks!
Old 11-27-13, 09:39 AM
  #158
FIGS
The Maker
FIGS's Avatar
static alignment should not be affected by this bushing change, its all dynamic. So alignment is not necessary though I suggest you decide on what type of toe settings you want to maximize your wear because if you just stuck with "Factory Spec" there is obviously a lot of sway between toe in or out.
__________________
Old 12-19-13, 11:04 AM
  #159
ms2619
ms2619's Avatar
I'm really interested in these, mine might be bad as well at 85K miles and my cars been hit on the left, i go through front tires every 20K miles if that...
Groupppp buy ????
Old 12-19-13, 10:45 PM
  #160
FIGS
The Maker
FIGS's Avatar
Groupppp buy ????
we have a large qty arriving next week and will have a sale between Christmas and New Years.
__________________
Old 12-23-13, 09:28 AM
  #161
FIGS
The Maker
FIGS's Avatar
back in stock. and on sale through the end of the year.
http://shopfigs.com/v1/index.php?rou...product_id=138
__________________
Old 01-20-14, 11:48 PM
  #162
FIGS
The Maker
FIGS's Avatar
Well you guys pushed me to it, now offering with bracket swap.
http://shopfigs.com/v1/index.php?rou...product_id=235
__________________
Old 01-21-14, 11:24 AM
  #163
WylieKylie
WylieKylie's Avatar
^ Awesome! I've been on the edge of ordering a set of brackets for about a month, glad I didn't!
Edit: Ordered a set last night, does that make me the 1st to order with brackets? I love being the guinea pig!
Old 01-21-14, 12:28 PM
  #164
sleepyray
sleepyray's Avatar
Hi FIGS, I saw this statement on your site:
'FIGS is happy to offer a $60 core charge for any returned brackets from the OE locations. Contact us for details"
would you kindly release some more detail or requirement? thanks!
Old 01-22-14, 08:31 AM
  #165
FIGS
The Maker
FIGS's Avatar
Well, if you ship back your original brackets with bushings installed we will credit the original transaction with $60. We will then refurb the brackets for reuse. Once I have cores built up I will offer then for slightly less than a new bracket set depending on condition. Most of these see little damage but might need a good cleaning.
__________________
Quick Reply: New Product Front F Bushing offering and eye opening video inside.
