New Product Front F Bushing offering and eye opening video inside.
#182
The bushings help "support" the alignment, so the toe numbers up front are critical to tread life.
__________________
Redefining Lexus Aftermarket Parts Since 2001
-- We are your Lexus suspension experts--
BCR - KW - PENSKE - OHLINS - HKS - GREDDY - STANCEPARTS
Links - Arms - SuperPro Poly Bushings - Solid Bearing Conversions - Motor Mounts
RB BBK's and 2P Rotors, G-Loc pads, Radium Fuel Systems
Custom Fabrication Design and Machining - Industrial 3D Printing - Laser Cutting
2018 USTCC Sportsman Class Champions - 2018 NASA ST5 National Champions
![](https://www.clublexus.com/forums/signaturepics/sigpic106840_3.gif)
#183
#185
shoot me you contact info and I will send one out.. Grease should be included though the bushings is pre-greased.
Mike
Mike
__________________
#186
#187
just installed the bushings. i feel a diffence in the steering while braking and i had a pull to the right and now its fixed. I HIGHLY RECOMMEND THESE BUSHINGS!!! now i got to send the old ones back and get that $60..
#188
Just and update i went to the dealership friday and my service rep told that my front tires haven't shown any uneven wear. He said, "those bushings you put on really helped!" i've put about 10000 miles on my car after installing them. I HIGHLY RECOMMEND EVERYONE INSTALLING THESE BUSHINGS!
#189
Ordered mine & installed earlier last month while having a new alignment & new set of PSS installed after reading up on the uneven tire wear (which my old tires had at the first 23k miles.
#190
Are these bushings going to lead to less forgiving ride?
I switched to poly prothane bushings on my previous ride, it turned out to be the worst mod
ever as the ride quality became unbearable.
As I read through the posts I noticed two options, duro80 & duro90.
Would the softer duro80 still fix the tire wear issue without sacrificing the ride?
Any feedback is appreciated.
#191
I just need to get my alignment done and hopefully have my new PSS tires last a good amount of time!
#192
I just installed these bushings yesterday and I have the 90A. I believe they only offer the 90 now. There is no difference in ride quality or harshness. I noticed a big difference in braking feel though. Before I could feel the flex and almost like a nose dive feel, now braking is solid.
#193
This is the reason we have consolidated on stocking the 90 duro only. The 80 might work for a 250 or a GS but the braking loads on the F impose a lot of force on this bushing and the large mass allows for quite a bit of damping to still take place. Let the shocks control your comfort and the bushings control your feedback. If anything these bushings allow better function of the dampers without the torsional effects of the bushing.
__________________
#194
I would like to thank Mike for answering endless questions on the phone and via text, ended up buying these bushings and some other parts. Definitely a cool human and a class act.
#195
No problem, that why I am here to support and educate.
__________________
