New Product Front F Bushing offering and eye opening video inside.
#228
I installed the bushings about 300-400 miles after I got new tires and there seems to be significantly more camber wear on the front driver side. I got the alignment done after the bushings were installed. I'm not sure if its normal or if the majority of the wear was caused before the bushings were installed. I ran almost twice as much camber on my STI and don't remember experiencing camber wear that quickly.
#229
This is the reason we have consolidated on stocking the 90 duro only. The 80 might work for a 250 or a GS but the braking loads on the F impose a lot of force on this bushing and the large mass allows for quite a bit of damping to still take place. Let the shocks control your comfort and the bushings control your feedback. If anything these bushings allow better function of the dampers without the torsional effects of the bushing.
#230
Mike
__________________
Redefining Lexus Aftermarket Parts Since 2001
-- We are your Lexus suspension experts--
BCR - KW - PENSKE - OHLINS - HKS - GREDDY - STANCEPARTS
Links - Arms - SuperPro Poly Bushings - Solid Bearing Conversions - Motor Mounts
RB BBK's and 2P Rotors, G-Loc pads, Radium Fuel Systems
Custom Fabrication Design and Machining - Industrial 3D Printing - Laser Cutting
2018 USTCC Sportsman Class Champions - 2018 NASA ST5 National Champions
#232
Anyone have these on a 250/350? On my 2nd set of front tires and it's already showing inner wear. Ideally I would have gotten the 90A but it seems like all the F's have them. Can anyone chime in?
#233
Mike
__________________
#234
#235
I'm a 350 owner with a set of FIGS LCA 90 durometer bushings installed on my car. I can't comment on the changes to the rate of inner tire wear as I've only put about 5k miles since the upgrade but I can absolutely vouch for the improved stability of the IS during trail-braking and the overall improved steering feel on both the track and cruising around town.
#237
Tech Info Resource
These bushings fix issues for people concerned about mechanical performance, not people who want to drag frame.
#240
I installed mine today.. Deflecting the LCA to remove & replace the bushing/bracket was a bit tricky, but other than that, it went well.
I know it's advised to immediately get an alignment, but I'm not too concerned at the moment... I just got an alignment about a month ago. During the post-install test drive, it seemed to consistently track straight as an arrow. I even did some "no hands on wheel" stops from ~30-40mph and it still tracked straight. Of course, I'll keep a close eye on tire wear for awhile.
-Mike
-Mike
