CL Vendor Products for IS-F New product details, group buys and more, specifically for the IS-F model from CL Vendors
Group Buy RRRacing/Penske ISF coilovers Group Buy
Old 03-29-16, 06:37 PM
  #136
Dnfwm
Dnfwm's Avatar
well this down right sucks. I was completely blowing my budget to begin with. Now it's an extra 300 (410 Canadian). I really gotta think about this. Can RR help us out any further on the price point since there was 7-8 of us instead of 5-6. Last time a group buy was done in November, you guys had the price down at 3000 for the DA's.
Old 03-29-16, 08:05 PM
  #137
3nergiz3d
3nergiz3d's Avatar
Almost makes it worth it to pony up that 410 dollars and buy the DA's as Penske is expecting a price increase next month. You know you are going to get a well constructed coilover with lifetime use. Also depends on what your application is and if another brand can fill the void till the dollar shoots back up.
Old 03-30-16, 06:24 PM
  #138
jat0223
jat0223's Avatar
Is anyone planning on installing these themselves? I belive I saw a DIY installation for coilovers but I can't find it now. Do these come ready to be installed or do we need to reuse parts from the stock ones?
Old 03-30-16, 06:56 PM
  #139
redcrxsi
redcrxsi's Avatar
I'm planning on installing myself at home in my garage
Looks like a pretty straight forward install the only thing I keep reading about it is resetting the bushings to neutral. I haven't quite figured out what that means or how to do it properly there's a couple of threads on it though. Hoping it makes sense after I start, I'm a hands on learner.
Maybe take a look at this https://www.clublexus.com/forums/is-...lover-diy.html
Also - when do our units ship?
Old 03-30-16, 07:38 PM
  #140
jat0223
jat0223's Avatar
I'm planning to do it myself in my garage as well. I believe I understand about resetting the bushings. Thanks for the link, exactly what I was looking for.
Old 03-30-16, 08:07 PM
  #141
redcrxsi
redcrxsi's Avatar
Cool, I might ping you if I get stuck!
Old 03-31-16, 06:35 AM
  #142
Biggu
Biggu's Avatar
I also plan to install myself ill be installing on my two post, loosing all arm bolts, then moving the car to the 4 post lift and tighting all the bolts in the neutral position.
Old 03-31-16, 08:58 AM
  #143
3nergiz3d
3nergiz3d's Avatar
Found this in the Swift Spring Install thread.. not sure if it applies to Coilovers as well for people who have the USRS.
"The goal is to have the suspension at normal ride height when you tighten the bolts. That way, you have no worries about the OEM rubber bushing being constantly stressed and breaking down prematurely.
If you are putting in poly bushings, there's nothing to worry about because the metal rotates in the polyurethane so you don't have the same issues. Also true of suspensions with spherical ball joints. No shenanigans at all, just bolt up and tighten."
Old 03-31-16, 12:01 PM
  #144
lobuxracer
Tech Info Resource
Senior Moderator
lobuxracer's Avatar
Received 4,081 Likes on 2,473 Posts
Exactly correct. Just another good reason to ditch the OEM bushings if you have the tools and ability.
The other thread discussing setting suspension to a neutral setting before tightening is here:
https://www.clublexus.com/forums/sus...ere-first.html
Old 03-31-16, 04:36 PM
  #145
Katin2
Katin2's Avatar
Lobux- you joining in on this group buy since we've got the numbers?
Old 03-31-16, 04:44 PM
  #146
5280ISF
5280ISF's Avatar
Thx guys, very helpful information. I will be giving the self install a try myself. Sounds like it is pretty straightforward.
Still have concerns about dialing the DA setup in, and getting the correct alignment specs....
Old 03-31-16, 06:31 PM
  #147
redcrxsi
redcrxsi's Avatar
+1 on the dialing in settings although I'm not worried about it. Rafi said they come dialed in but I may want to change to make them even more road friendly (comfortable). Won't know until I go for a ride.
As far as alignment I though I remember reading somewhere that if you aren't going more then 1in in the front it's fine without extra aftermarket stuff i.e. Figs.
I think Rafi said they come preset at about .75in lowering in front and .5in rear. Still need to measure of course.
Old 04-01-16, 02:12 AM
  #148
RRRacing
Sponsor
CL Vendor - Starter
RRRacing's Avatar
Received 1,415 Likes on 648 Posts
The stock setting is about 1" lower front, 0.5" rear, you can easily change that to whatever your liking is, higher or a bit lower.
Rafi
__________________
We Engineer Track Proven Upgrades For Your Lexus!
SUPERCHARGERS : ECU TUNING : SUSPENSION : EXHAUST : PPE MASTER DEALER
Online Store: www.RR-Racing.com
Email: Contact@RR-Racing.com
Phone: 484-756-1777
Facebook : Youtube
Old 04-01-16, 11:56 AM
  #149
redcrxsi
redcrxsi's Avatar
Thanks Rafi,
Regarding camber - for a street driven car is 1in too much to get within factory specs?
Old 04-01-16, 12:37 PM
  #150
jspecvtec
jspecvtec's Avatar
Thanks Rafi, Regarding camber - for a street driven car is 1in too much to get within factory specs?
I'm a tad bit outside oem specs on front camber with a 1 inch drop.
Quick Reply: Group Buy RRRacing/Penske ISF coilovers Group Buy
