Group Buy RRRacing/Penske ISF coilovers Group Buy
#181
#183
Feel has little to do with whether the car is fast or not. Maybe driver confidence is a problem, but a talented driver can push a car that doesn't feel good faster than one that does if the feel good setup isn't as fast.
#184
Guys, do you realize that the lower single adjusment collar on Penske shocks are different that a double collar where you counter two collars against each other? Penske has moved to a single collar because on non-strut cars, there are no rotation forces on the collar like in a McPherson strut... so they simply use two set screws to hold the lower collar in position.
In order to adjust the lower collar you simply loosen the two set screws, then stick any rod like object into one of the holes (like a bolt, allen wrench, etc) and the lower collar will EASILY turn.
You do not need a spanner wrench.
-Rafi
__________________
We Engineer Track Proven Upgrades For Your Lexus!
SUPERCHARGERS : ECU TUNING : SUSPENSION : EXHAUST : PPE MASTER DEALER
#186
-Mike
#187
Got my Penske's last night but ran into a small problem. It looks like the Penske's wont work with the gen 1Figs Mega Rear lower control arm. It Could work, if you don't mind damage on the Penskes from rubbing the side of the control arm but no way I'm comfortable with that.
I spoke with Mike at Figs last night and he assured me that the Gen 2 was designed to combat this as well as some other enhancements. I ordered another set of mega gen 2 arms and got expedited shipping on them.
#188
#189
#190
the USRS is fine and has no issues, just the rear control arm since I have Figs don't work so well. the Gen 2 are supposed to correct the issue but if you are on stock control arm for the rear lower you will be fine.
#191
Originally Posted by RRRacing
We managed to get about 1/3 of the orders out on Friday. We should be able to get all the orders out by end of this coming week.
Rafi
Rafi
Jeff
#192
Installed mine and Mark's (thegrunt) yesterday.. Whew..long day! The majority the the time was spent figured everything out with my car first.. We were able to get Mark's done in ~3-3.5 hrs.
-Mike
-Mike
#193
Any time saving tips you can share for install or is it more of just having familiarity?
Ride/handing impressions?
Thanks for sharing!
