CL Vendor Products for IS-F New product details, group buys and more, specifically for the IS-F model from CL Vendors
New Product RR-Racing ISF ECU Tune.... FINALLY!!!
Old 02-19-16, 09:13 AM
  #901
juanmedina
juanmedina's Avatar
Originally Posted by idoke1
^^LOL. I got used to it. Was filmed on my galaxy edge.
Have you compare that video to the one you did 3 months ago?
Old 02-19-16, 09:42 AM
  #902
idoke1
idoke1's Avatar
Yes, it gets to 120 mph almost 2 seconds faster. I remember I was able to get to 120 mph in about 14.8 secs. Now I can get it to 120 mph in 13 secs.
Edit: I just watched my video from 3 months ago and I noticed part of the beginning of the video is slightly cut off. Most of my launches start right at idle. The one posted 3 months ago shows it from 2.1k rpm and up. I remember the temps during that run was in the low 30s. It felt great! The new one I posted with the tune, the temp was in the mid to high 50s. I wonder how it will run when temps drop down to the 30s.....
Old 02-19-16, 09:59 AM
  #903
Compthis
Compthis's Avatar
Temps make a huge difference. At the track I normally get up to 210Km/H running up the back straight but my last day out was very cold, allowing me to run up to 230Km/H. Everything the same, just much colder temperatures.
Old 02-19-16, 11:08 AM
  #904
Bigjon3475
Bigjon3475's Avatar
I'm not a drag racer nor have I ever taken a car to the strip (flame me if need be) but instead of raising the rev limiter -- so you're not bouncing off of it as you pass through the gates -- could you not run a taller tire? I don't know how much there is to spare but what would be the results of a tire .25" to .5" taller? No differences in where you're at as you pass through the gate?
Old 02-19-16, 11:53 AM
  #905
RSXiMUS
RSXiMUS's Avatar
A taller tire will probably have a larger rotating mass and will also behave like you have a taller final drive ratio. Both counterproductive in drag racing, you might be able to cross the line without bouncing off the limiter but you'll also be slower getting there.
Old 02-19-16, 12:23 PM
  #906
tas02
tas02's Avatar
6800 rpm = 113 mph w/the stock 255/35 x 19 rear tire.
In 2012, Caymandiver used a 245/40 x 18 drag radial for his 11.87 @ 119 mph 1/4 mi., crossing the traps in 5th. With the 7200 limiter, I'm gonna go with a 265/40 x18 & try shifting @7k.
Old 02-19-16, 12:29 PM
  #907
zebani
zebani's Avatar
Quick question for anyone who can help me, I noticed in the video that the traction control was off the whole time. My traction control doesn't stay on after I pass 20mph or so. Is there a setting that can be changed or any other reason that might cause that?
Old 02-19-16, 12:36 PM
  #908
ISF4life
ISF4life's Avatar
Peddle dance will get rid of it , until u restart the car
Old 02-19-16, 12:44 PM
  #909
zebani
zebani's Avatar
Never heard of it until you mentioned it. I will be checking it out Thanks
Originally Posted by Tungstn-IS
That's pretty much how it is done
I start the car while pushing parking brake and regular brake
- Hit regular brake twice while holding parking brake..hold the regular brake on the second hit
- Pump the parking brake twice while holding the brake
- Hold it on the second hit and then push the brake pedal twice again
It takes all of about 5 seconds to do LOL.
Old 02-19-16, 12:51 PM
  #910
Pie
Pie's Avatar
You need to told the traction control button down for a few seconds. It'll turn everything off except the E-LSD
Old 02-19-16, 01:03 PM
  #911
zebani
zebani's Avatar
Apparently holding the button down doesn't turn the traction all the way off but the pedal dance does. Interesting...
https://www.clublexus.com/forums/is-...t-results.html
Old 02-19-16, 01:08 PM
  #912
ISF4life
ISF4life's Avatar
WHEN U HOLD IT ABOUT 5 SECONDS ONLY FOR TEMPORARILY, BUT WHEN U DO PEDDLE DANCES, IT WOULD DO IT WHOLE ENTIRELY UNTIL YOU RESTART THE CAR PIE MUST BE A NEWBIE LOLZ
Old 02-19-16, 01:10 PM
  #913
BS ISF
BS ISF's Avatar
you only have to hold it down. pedal dance not needed.
  #914
RRRacing
Sponsor
CL Vendor - Starter
RRRacing's Avatar
Received 1,416 Likes on 648 Posts
A bit off topic, but look at what we have been working on
__________________
We Engineer Track Proven Upgrades For Your Lexus!
SUPERCHARGERS : ECU TUNING : SUSPENSION : EXHAUST : PPE MASTER DEALER
Online Store: www.RR-Racing.com
Email: Contact@RR-Racing.com
Phone: 484-756-1777
Facebook : Youtube
Old 02-19-16, 01:56 PM
  #915
zebani
zebani's Avatar
Has anyone else experienced VSC light coming on after the ecu installed back on the car? Mine came on twice but went away after I turned the car off and back on.
Quick Reply: New Product RR-Racing ISF ECU Tune.... FINALLY!!!
