New Product RR-Racing ISF ECU Tune.... FINALLY!!!
#992
Guys, there is no way we will every scam anyone, that is contrary to every principle by which we do business. Either we do it right, or we wont bother doing it.
For example, we recently reported we were working on an upgraded Throttlebody tune. Then we reported it didn't make any power. If we were so inclined, we could show dyno results showing 7-8hp pickup, and make money on an upgraded tune and bigger throttlebody... but we leave that crap for other's to do.
We just got a mailer from our distributor with info on the new Takeda intaka for the RCF. They claim +15whp. Absolutely ridiculous, especially coming from a supposedly reputable company!
Rafi
Rafi
#994
Sponsor
![](https://www.clublexus.com/forums/images/ranks/rank-vendor2.gif)
Rafi
__________________
We Engineer Track Proven Upgrades For Your Lexus!
SUPERCHARGERS : ECU TUNING : SUSPENSION : EXHAUST : PPE MASTER DEALER
#995
This makes me happy but will it be able to be tuned elsewhere? also I made 415whp and 376wtq on a mustang dyno which reads 10-20% lower than a dynojet so could I expect a lot more? I have sikky headers and a straight pipe.
#997
Sponsor
The problem with many dynos is that they depend on the dyno operator entering the RPM to wheel speed calibration (i.e. Mustang dyno, Dynapack, Dynocomp, etc).
So what the operator does is he drives the car while holding the tachometer at a certain RPM, say 4000... then while driving it at 4000, he locks in the calibration between the engine speed and wheels speed.
Problem is that even small errors of 100-200rpm can easily result in a 10-20+hp miscalculation.
The easiest way to detect that something is wrong is to look at the dyno plot. If you know that say a stock ISF is supposed to redline at 6700, and the dyno shows something else, then you know that the calibration is incorrect, and the HP/TQ numbers are either too high or too low.
Of course, if the dyno operator always uses the same calibration factor for a certain make/model, then at least the results will be repeatable from one car to the other (or from one day to another). But the problem is, you really don't know, and the results are always open to intentional or inadvertent manipulation.
We like DynoJet dynos because they use an actual RPM pickup from the ignition wires or OBD port for RPM logging. HP and TQ numbers are calculated strictly from how much power it takes to spin up the standard Dynojet drums. So there is no user-input calibration data to add to measurement variability.
Rafi
__________________
#999
I assure you we ran it on the dyno 5 times and the highest we got was 415whp 376tq, my rear diff is different though it was upgraded for the track. instead of topping out at 170 it stops me at 138. but those where my numbers I just need to get my dyno graph on digits. they did my pull from 6th which is closest to 1
#1000
Rafi
Rafi
I could use a dynojet just requires me to go for a longer drive, they had everything correct from my view and the tuner is experienced. it did fairly well on the dyno but having a After market Tuner might make a huge difference as well.
#1002
Sponsor
Simon
__________________
#1003
Not sure if you guys have already covered this, but question to Rafi - Do you guys know if the ISF 08-14 ECU's are interchangeable? Meaning, have you taken the tuned ecu out of your shop car and tried plugging it into a customer's car to see if it works? I'm still tempted to get my hands on a spare ecu if it does in fact work since my F is my only source of transportation, I can't have any downtown of sending it in.
#1004
Computer, Engine Control
Production Date: 03/2010-08/2010
Production Date: 08/2010-08/2012
Not sure of the differences other than mfg dates. They have different part numbers when you try to find them. Looks like they're between $720 and $840. With the newer one being more expensive.
#1005
Rafi
Rafi
I respect that you tell the truth, hopefully these dyno results stay repeatable, and I will guarantee you will cont. to get business from the folks here.
