New Product RR-Racing ISF ECU Tune.... FINALLY!!!
#1021
Uh oh guys....
First issue with my flash with the 7200 rev limit.
Anyone of you guys with the higher rev limit having this issue? After 6800 it seems the transmission slips or something... Already PM'd Rafi, let'ssee what's going on...
Check out the video....pay attention to the needle as it hits 6800.
#1022
I can't tell exactly when you tried to shift it but it seemed more like you pegged it off the limiter and then shifted. Edit- after researching it several times I kind of understand. It's like the transmission unlocks the TC at 6800. Interesting...
#1023
I was purposely running it out till the rev limiter to show the issue. It would accelerate till 6800 normally, then something just "slips" or something and the revs shoot to 7200. Pay attention to the needle once it hits 6800, it shoots to 7200. It's as if I shifted into Neutral right at 6800.
#1028
Mine does that too, jumps from 6800 to 7200... I wasn't sure if it was just the tach bumping up or trans unlock... Odd. It's hard to time the shift when it jumps like that.
#1029
Wondering if any of the earlier guys are having issues.....
+1 on timing the shifts with the issue, with the way it jumps from 6800 to 7200 it kinda defeats the purpose of the higher limit since as soon as it gets to 6800, it jumps to the 7200 rev limiter pretty much immediately.
#1031
Ah I get what you're saying.. Let me address this to Rafi right now!
-Josh
-Josh
__________________
Your #1 Dealer for Aftermarket Performance Products
Orange County, CA
Text/Call: 213 394 2886
Orange County, CA
#1032
I'm hoping it's just an issue with the 11+ and they can have a remedy to fix it since I doubt RR would release the higher rev limit tune knowing the ECM is not allowing full lockup after 6800 rpms.
I don't pretend to know how our magical 8speed autos work but I assume the TC stays locked during shifts also? If it really is an issue with TC unlocking after 6800 then locking up for the next shift ect, that doesn't seem too healthy for the transmission?
#1033
Sponsor
All ECU's since what 2000 and or the days whenever that manufacture went to CAN bus systems are programmed to a specific VIN and aren't interchangeable. The answer should be no, it won't work.
My year figure could be off a little. I'm basing that off Volvo switching to fly by wire and CAN bus that year.
That is correct, you cannot swap ECU's around from car to car, it won't work.
Rafi
__________________
We Engineer Track Proven Upgrades For Your Lexus!
SUPERCHARGERS : ECU TUNING : SUSPENSION : EXHAUST : PPE MASTER DEALER
#1034
Uh oh guys....
7200 Rev issues - YouTube
#1035
Sponsor
sorry guys, at this time, I don't have the answer but from the video it looks like the torque converter is unlocking at the stock redline.
Not sure why this is happening, as our shop car is a 2010 and this definitely does not happen. We also tested it on a 2008 on the road, and this did not seem to happen.
We will send out an email to everyone who has received a 7200 rev limit tune and survey which years are having issues, and which are not.
If we find that the issue is limited to certain years, that would require re-flashing the TCM on those specific cars, which should be possible. The TCM is a separate chip located on the ECU board.
-Rafi
__________________
