New Product RR-Racing ISF ECU Tune.... FINALLY!!!
#1087
#1088
I've been wanting to do this, just can't be without my car at the moment since it's my daily. Already craving more power after I/H/E...
The OBII reflash would be soooo convenient! I know a certain other company mentioned that possibility, but I have more faith in RR-Racing.
#1089
![Smile](https://www.clublexus.com/forums/images/icons/icon7.gif)
Been nearly 4 weeks since several owner had there ECU flashed, it seems like know wants to be the first one to post dyno numbers. At this point several Owners should have exceed the recommendation put forth by RR Racing regarding how long it takes ECU to learn. If tune did not hold and ECU reverted back to stock they should know by now. As for as HP is concerned for me anything over 30 hp is great, 20hp to 30 hp is good. Hopefully, we will have some results soon keep us posted guy's.
#1090
Sponsor
![](https://www.clublexus.com/forums/images/ranks/rank-vendor2.gif)
Update 3/2/2016:
Rafi
- We are working on a transmission reprogramming tune, but I do not have an exact release date yet. The tune will allow for us to change the shift RPM points in automatic mode, and keep the TC fully locked up to the programmed rev limit in Manual mode.
- We will also formally release the OBD flash device on March 8th. Price will be $795 for the tune including the flash device.
Rafi
__________________
We Engineer Track Proven Upgrades For Your Lexus!
SUPERCHARGERS : ECU TUNING : SUSPENSION : EXHAUST : PPE MASTER DEALER
#1091
been nearly 4 weeks since several owner had there ecu flashed, it seems like know wants to be the first one to post dyno numbers. At this point several owners should have exceed the recommendation put forth by rr racing regarding how long it takes ecu to learn. If tune did not hold and ecu reverted back to stock they should know by now. As for as hp is concerned for me anything over 30 hp is great, 20hp to 30 hp is good. Hopefully, we will have some results soon keep us posted guy's.
#1093
#1094
Sponsor
We haven't finalized the pricing, but I promise it will be reasonable.
Rafi
__________________
#1095
Update 3/2/2016:
Rafi
Rafi
If you guys can make the transmission shift closer to the rev limit in auto, that would be pretty sweet.
Also when the time comes, is the transmission controlled by the main ECM also or is that a separate computer that needs to be sent in to be flashed?
