Hmmm...Am I missing something here? How come the whp seem kind of low to me? Stock ISF makes on average 350whp, with an exhaust 375whp, Headers 400whp give or take. I thought the tune alone would provide 20-50whp/torque more? Based on the chart? Now with the throttle body mod another 10whp? To a total of 420whp? I'll take that any day but just seems low or I'm definitely misunderstanding something...
They're approaching 500 crank hp (100 hp/liter). It's going to start getting pretty expensive to make more power out of the motor at atmospheric pressures (hint hint).
Rafi,the 410-412whp = tune,exhaust & headers.........
was it with sikky or ppe?
Intake: drop in? What brand?
We had identical results with Sikky and PPE headers, PPE's on our shop 2010 ISF, and Sikky on JDMV8's 2008 ISF. We used K&N drop in filter, and I believe JDMV8 used some JDM filter
Rafi
__________________
We Engineer Track Proven Upgrades For Your Lexus! SUPERCHARGERS : ECU TUNING : SUSPENSION : EXHAUST : PPE MASTER DEALER
So we are almost finished fitting the RCF throttlebody for testing next week. Here is what needs to be done to fit an RCF TB on and ISF intake manifold:
Machine new bolt holes into the RCF TB, it is wider than the ISF TB.
The lower left hand corner of the RCF TB hits the aluminum coolant passage, so you need to grind the coolant passage a bit, and shave the plastic left side TB cover a bit.
Port the intake manifold to match the RCF TB.
Crossing our fingers that this will make some power, or it will be an expensive little experiment
__________________
Rafi,
I appreciate the talk yesterday. Either I forgot to ask or I forgot the answer:
The SC kit I presume will be tuned for stock decat headers etc right? Let's say I were to simply do the SC, exhaust and decat.
I presume the numbers that end up beinh published will be based on a mostly stock vehicle and graduate upwards? If not: I'd be happy to explore this.
Of course this happens right after I buy the useless $500 titanium one
Just got one myself and was thinking the same thing.
Originally Posted by FFM
They said high flow air box. Nothing about the pipe. I assume they would still use their existing and are just modifying the box and TB?
I'm thinking the tube might have to be bigger. If stock tube is 79mm ie same size as TB (I think that's right) then the tube would be smaller and wouldn't line up as well.
Rafi,
Its clear to us now that once the induction side is improved with the larger MAF intake and TB, headers really help... and that tells us that stock decatted manifolds will create backpressure after about 405whp. So with the SC, we expect that headers will be well worth the expense. That said, we can custom tune your car with stock manifolds and SC.
First, our new intake works with ANY elbow upgrade... so you don't have to throw that away.
When upgrading the TB, you have to do some minor porting work on the intake manifold inlet bore.
-Rafi
__________________
wow thats awesome, I know a guy making close to 400 crank hp on a 4cyclinder all motor daily driven honda using this rcf throttle body modified to work with his car, if the same holds true for our car and this really makes some power I would definitely cop. Supercharging and Turbo is fun, but I was always a sucker for high powered tuned n/a motors.
