New Product FIGS CNC Billet Battery Bar V2
About 10 years ago we designed a machined battery bar to help keep flat top batteries from slipping around on Lexus vehicles and in universal applications. At the time it became so popular that many were asking if it would work on their factory batteries as well. Introducing our new V2 Battery Bar that is designed to do both and add a special FIGS style to your engine bay. The first batch is back from anodizing today (orange will be a little longer) and intro pricing is live on the site at nearly 25% off with free shipping. Grab them while they last as we just did a short run on these and only holding limited quantity.
The IS-F requires a new front J-bolt so be sure to add that into the options.
http://shopfigs.com/v3/index.php?rou...v2+battery+bar
__________________
Redefining Lexus Aftermarket Parts Since 2001
-- We are your Lexus suspension experts--
BCR - KW - PENSKE - OHLINS - HKS - GREDDY - STANCEPARTS
Links - Arms - SuperPro Poly Bushings - Solid Bearing Conversions - Motor Mounts
RB BBK's and 2P Rotors, G-Loc pads, Radium Fuel Systems
Custom Fabrication Design and Machining - Industrial 3D Printing - Laser Cutting
2018 USTCC Sportsman Class Champions - 2018 NASA ST5 National Champions
In the past, blue was a slow moving color and unfortunately we have already completed our machining run with a few part stuck at anodizing. I will see what we can do.
__________________
contact@figsengineering.com
Our bar is designed for spacer inserts that we can make, but it might be as easy as a different J bolt..
Also, looks like we might be able to convert 5 bars to blue at our anodizer, will keep you posted.
Mike
__________________
can you email me a picture of your current setup and which group is teh battery. It looks like they have 1500 in a typical stock height of 7.87 so it should work without issue.
It's a Group 34 with a spacer placed below to bring it Group 24 height - without the spacer I think I recall the j-bolt wasn't threaded far down enough to clamp down adequately onto the battery.
Blue confirmed but just a few. Will list them on the site tonight.
__________________
Hi guys, a quick update on Blue. Our Anodizer is facing a few challenges with blotching coming though from the base material and we are going to have to reprocess the parts in an attempt to get the finish we want. Sorry for the additional delay, we should have another run through Tuesday/wed of next week and we will update you all with the outcome. The coloring easter eggs can be a challenge but we want to meet out standards so it will be a bit longer .
__________________
Totally forgot to grab a pic for you. Do you still need it or was the description of the battery setup good enough? IIRC, the stock battery clamp fit a bit funky, but I haven't been underhood since my last oil change.
-Mike
