CL Vendor Products for IS-F New product details, group buys and more, specifically for the IS-F model from CL Vendors
Sale Lexus IS-F Interior LED Lighting Conversion! See Installed Comparison Photos!
Old 05-19-17 | 12:40 PM
Diode Dynamics's Avatar
Diode Dynamics
Former Sponsor
Arrow Lexus IS-F Interior LED Lighting Conversion! See Installed Comparison Photos!
Lexus IS-F Interior LED Conversion Kit
At Diode Dynamics, we carry a full line of LED bulbs, to replace your Lexus IS-F dome lights, license plate lights, trunk light, turn signals, and more!
We carry the brightest, highest-quality bulbs at the lowest prices. Your order will ship same day, and we're here if you need us for support and service. These LED bulbs are designed by us here in St. Louis, and every bulb carries with it a three-year limited warranty.
Your dome, map, and cargo lights use an incandescent bulb from the factory, giving it a yellowish color. By replacing them with an LED, you can add a luxurious and modern look to your Lexus, with a cool white color, just like the lights on newer luxury vehicles. You can also increase the brightness with SMF4 or SMD12 Board, to improve the performance of your dome light.
The installation is 100% plug-and-play, just replace your factory bulbs!
Bulb Design:
SMF2: This bulb has a standard festoon base, with two forward-facing 5050-size Epistar SMDs. Direct replacement, plug and play.
SMF6: Standard festoon base, with six 5050-size Epistar SMD chips arranged on a rectangular panel.
SMD12 Board: This is an LED panel, fitted with 12 5050-size Epistar SMD chips. Comes with spring-loaded festoon-style adapter for direct installation. Plug the adapter into the bulb socket, then just stick the board in place with the mounting adhesive pad. The board-and-adapter design allows for extremely high brightness compared to a simple bulb.
Brightness
SMF2: (16 lumens) Slightly lower brightness than OEM bulbs, but still provides the crisp, modern color of LED.
SMF6: (94 lumens) Slightly higher brightness than OEM bulbs.
SMD12 Board: (118 lumens) Much brighter than OEM bulbs. These are bright!
Lumens: BUYER BEWARE! Most sellers just provide "calculated" lumen numbers, based on the maximum potential brightness of the LED chips on the bulb. For example, if a bulb has five 10-lumen chips, they will rate it at 50 lumens. However, this is not accurate, as the design of an LED bulb does not get rid of heat fast enough to run the LEDs at maximum.
These "calculated" lumen ratings are much, much higher than the true, measured light output, so it will look like competitors' bulbs are brighter than ours. This is because Diode Dynamics does not provide inflated "calculated" numbers; we believe it is misleading. We test the actual brightness of the bulbs in our lab, to provide real lumen output measurements. Our measurements are accurate, but they are usually much lower than the misleading "calculated" figures.
All products by Diode Dynamics are backed by a 30-day satisfaction guarantee and a three-year limited warranty.
Click Here: Lexus IS-F LED Replacements
Questions? Feel free to ask here, PM, email contact@diodedynamics.com or call us: (314) 205-3033
*PM us for the free-shipping code* (U.S. forum members only)
Thank you!
Nick C.
Diode Dynamics
Old 05-24-17 | 10:55 AM
Diode Dynamics
Former Sponsor
Here's a photo with our red LED replacements installed in the ISF door light location
HP5 Red (92 lumens)
Nick C.
Old 05-26-17 | 04:55 PM
djyoshi626's Avatar
djyoshi626
Does the SMD12 have to be mounted on the exterior of the trunk light housing? Do you offer a full kit for the interior of the car or is every item a la carte?
Diode Dynamics (05-30-17)
Old 05-30-17 | 08:04 AM
Diode Dynamics
Former Sponsor
I believe the SMD12 will not fit inside the lens cover, but we have direct replacements that will. The SMD12 and Flex-light are the two brightest options and produce the most usable output.
We have separate listings for the IS-F by each location.
If you have any questions on which models to select, please feel free to give us a call: (314) 205-3033
Thank you!
Nick C.
Old 06-20-17 | 01:28 PM
Diode Dynamics
Former Sponsor
Diode Dynamics LED replacements for the IS-F Vanity lights installed
Nick C.
Old 06-23-17 | 03:27 PM
Diode Dynamics
Former Sponsor
With Diode Dynamics HP5's installed
Nick C.
Old 07-06-17 | 03:37 PM
MileHIFcar's Avatar
MileHIFcar
Nick,
For clarification purposes for the members here can you list the bulb part #'s by year for frame of reference before ordering? Example the 2008-09's have a different front dome set-up than the 2010+..........If I'm wrong about the 2009 set up someone correct me?
I'm wanting to order the entire interior led replacements...........2 bulbs for the front dome lights, 1 bulb for rear dome light, 1 bulb for trunk, and red led replacements for the doors
Are they all 194's? Can someone verify that has changed these for 2010+?
Thx
Old 07-06-17 | 03:39 PM
Diode Dynamics
Former Sponsor
Originally Posted by MileHIFcar
Nick,
Thx
Thank you for posting!
Unfortunately, we've only had a 2008 in for testing, but it's unlikely the interior bulb sizes have changed from year to year. Most Lexus models use the same interior housings, and many of those housings are indeed 194 sized bulbs.
If you have any questions about fitment, or would like more information, please feel free to reach out to us: contact@diodedynamics.com or call us: (314) 205-3033
We can help you find the replacements you are looking for
Nick C.
Old 10-16-17 | 04:11 PM
Diode Dynamics
Former Sponsor
Don't forget to send us a PM for the free-shipping code!
(U.S. shipping addresses only)
Thank you,
Nick C.
Old 10-19-17 | 02:39 PM
FinLIFE's Avatar
FinLIFE
Anything with modules for the front drl?
Old 10-19-17 | 02:57 PM
Diode Dynamics
Former Sponsor
I'm not quite sure what you are referring to, but please feel free to give us a call if you have any additional questions: (314) 205-3033
Nick C.
Old 10-25-17 | 12:37 PM
FinLIFE's Avatar
FinLIFE
Referring to the front drls on our cars. Perhaps making them drl/turn signals?
Old 10-25-17 | 01:05 PM
Diode Dynamics
Former Sponsor
If you are referring to the factory LED DRLs, it's certainly a possibility, but not something we've looked into for the ISF. Our engineering team is always working on new products, but that's not on the list at the moment.
Nick C.
Old 05-25-23 | 01:18 PM
Diode Dynamics
Former Sponsor
🚨 Our Memorial Day Sale is LIVE!!! 🚨[/CENTER]
➡ Up to 15% OFF Sitewide
10% OFF JL/JT Elite Series Headlights
➡ Free US Shipping on any orders over $300!
Excluded: F150 Elite Series Headlights, and F150 Elite Series Fog Lights
John C.
Diode Dynamics
Hours: Monday-Friday 10 a.m. - 5 p.m.
Email: contact@diodedynamics.com
Phone: 314-205-3033
Sale ends 11:59 p.m. CST on Friday, 6/2/2023. Cannot be combined with other coupon codes.
Old 06-01-23 | 01:43 PM
Diode Dynamics
Former Sponsor
[MEDIA=youtube]9mbEheOtrpU[/MEDIA]
⏳ WARNING! TOMORROW IS THE LAST DAY TO SAVE! ⏳
Up to 15% OFF All Lighting Upgrades
15% OFF Stage Series Rock Lights & HitchMount LED Pods
10% OFF Elite Series JL/JT Headlights
FREE US Shipping on any order over $300!
No coupon code is required.
Click HERE to shop lighting upgrades for your ride!
🚨 Sale ends 11:59 p.m. CST on Friday, 06/02/2023. Cannot be combined with other coupon code 🚨
John C.
Diode Dynamics
Phone: 314-205-3033
Xwakeboard
IS F (2008-2014)
14
02-02-21 06:04 PM
3GSShoe
06-23-18 02:30 PM
Joe Z
IS F (2008-2014)
119
12-30-15 12:12 PM
Paul B
RX - 3rd Gen (2010-2015)
06-09-12 03:50 PM
rclab1
01-12-08 12:16 PM
