** GB on Torque Master Spark Plugs, All Models ** back by popular demand **
Original CL Sponsor since 1999
Innovative designed Torque master spark plugs available for all models
The Torque Master spark plug has been designed, engineered and manufactured to provide maximum horsepower, torque, fuel economy and reduced emissions. Our unique, patented "Field Effect" design also gives the Torque Master spark plug the ability to last many times longer than conventional spark plugs
Don't be fooled by those 'gimmick' plugs whose slightly-modified appearance is more 'show' than 'go'. And why settle for 'business as usual' plugs whose designs haven't changed for dozens of years, when you can get the plug that has the big spark plug manufacturers paranoid! What do you stand to lose ....... except maybe performance?
Torque Master spark plugs are available for all makes and model of automobiles -- foreign and domestic -- motorcycles, marine, and off-road vehicles. Torque Master plugs are also available for special high-performance racing applications, such as turbocharged, supercharged, nitrous-oxide, and h! igh-compression engine.
Regarding spark plug gap, we only make two sizes. Our standard size, which has an equivalent gap of about .120" and the "S" plug, which has an equivalent gap of about .090". The standard plug requires between 21,000 to 25,000 volts to fire under full pressure. Our "S" plugs require between 16,000 to 18,000 volts to fire under full pressure. The "S" plugs are designed for high compression racing applications, turbocharged, supercharged, NOS, etc. The gap on a Torque Master spark plug cannot be changed as it is an integral part of the overall design.
$11.50 ea plug, FREE SHIPPING!! (USA only)
ORDER HERE and for more information on Torque Master Spark Plugs
USE code TMCL, I will adjust the pricing opon invoicing
GB ends 7/5/05
GB ends 7/5/05
exclusive matchup
Originally Posted by Lyrical
How do these plugs compare to the stock ones already on the GS? Doesn't it already have like Nology's on em?
but in terms of long term reliability and durability that's what i would want. these suppose to last for a very very long time
I am trying to understand the attraction to these plugs. DO they REALLY work well enough to warrant replacement of the stock plugs. I could see it if you were due for plugs. I would make a decision then because I NEED plugs. But some of the ads suggest that they are good enough to switch out good stock plugs and notice an immediate difference.
Somone mentioned long life....the stock plug is good for between 90,000 and 120,000 miles How much more life do you need?
Bottom line is: I have been extremely happy with the stock plug, and I am WAITING for a good enough reason to compel me to switch from a KNOWN entity to something else.
How about horsepower gains that can be measured and reported on a chart for all to see, or gas mileage increases that show appreciable improvement.
THAT would make me switch.
exclusive matchup
to be honest, if i were given the chance to do it again, i wouldn't put on the tm plugs. i really don't see anything significant out of it. maybe on charts there is something but i am not seeing that in real life that's for sure
but you are right, as replacements they are definitely good choice
oh and about the stock plugs, yup they are SUPPOSED to last that long, but when i chnaged my old ones to tm plugs a at around 50k miles, my old ones were pretty torn already. don't ask me why
Forum Administrator
I'm exactly opposite Rominl on this one on the plugs. I loved the TM plugs in my GS when it was NA, and when I changed them out for stock ones (for a driving / dyno event, wanted new plugs but just didn't get a set of TMs in time) I felt a noticable difference in power level and responsiveness in my 98 GS400 - lower/less with the OEM Denso Irridiums than with the TMs. I dynod after putting the OEM plugs back in and was down in power and TQ. I can't say for certain that it was all due to the plugs (humidty, temp were different) though.
I personally never would leave a set of plugs in a car for 100K miles... 30K is about max for the long life type like Denso Irridiums. They WILL last that long, but you don't get maximum performance out of them.
Forum Administrator
https://www.clublexus.com/forums/performance/50745-tm-dyno-results-awesome.html
exclusive matchup
Forum Administrator
Originally Posted by rominl
hey dave, nice to see other comments. i am curious, when you said you put back on the oem plugs and got lower numbers with dyno, did you put in new plugs or the old ones?
I agree with Dave, I loved my TM plugs when I had them. The car felt like it had better throttle response and revved faster through the rpms. It's a great mod for the price...
Former Sponsor
I agree also, I changed to them at about 80k and the car behaved very well. I believe it was a twofold improvement:
1. New plugs period-better performance
2. TM's better performance period
