** Genuine Toyota 90915-20004 Oil filters are in Stock!! **
#31
Thanks jvillagran... good info. Further searching seems to indicate that this filter cannot be used on the RX300, so I guess my GS will be the only Lexus to get the special filter treatment.
#32
Originally Posted by jvillagran
The top of the filter(GUTS) will come sealed from the factory,so as long as you don't submerge them in water you will be fine.
Oh yeah this is my second case
I don't know if any one remembers that this filter is very similar to the TRD Japan(red) oil filter and it's half the price.
![Woot](https://www.clublexus.com/forums/images/smilies/woot.gif)
#34
Forum Administrator
![](https://www.clublexus.com/forums/images/ranks/rank-admin2.gif)
Originally Posted by GS2006
Just curious, what filter was used on the engines that had the oil sludge problem? Could there be a reason this filter is no longer used?
Thanks
Mike
Thanks
Mike
Different filter (see response above about RX300 which should have same one) and not at all related.
The reason that this filter is no longer used (my understanding) is that it costs more to make than the current one... Basically over engineered and didn't provide a good profit margin
Thank you to Steve and Carson for tracking them down and bringing them tous.
#35
This is the filter you want and can no longer find in the US.
I noticed this site shows it fits the GS430 up to 2005. So it does not fit the GS430 2006?
Mike
#36
Originally Posted by OLP
Well they arent' the same price. $13 MSRP against $5.41 is kinda crazy to say they aren't making anything.
Also, what's so great about this filter?
I mean Mobil 1 and K&N and considered top dogs. I can get the Mobil 1's for roughly $8 on sale which is a 30% savings over this one.
I don't see why paying $11 per filter at a "discount" is any bargain![Sad](https://www.clublexus.com/forums/images/smilies/sad.gif)
Cliff notes: 90915-20004 has a superior filtering media
#37
Everything in Moderation
Why won't it fit the RX300? I've used the same filter # for the ES/IS as my RX.
Just curious??
Just curious??
#38
I began buying both K&N & Mobil1 recently, when these filters went away, because I just couldn't bring myself to put the average crap filter in my GS. But I just bought a case of these babies again, because, well..., I just hadta.
Having said all that, I don't think anyone has provided any real concrete proof that these filters actually do a better job than K&N or Mobil1, etc. Except for what is on Bobistheoilguy.com, I think most of the filter hype is a bunch of hooey. That's why when one comes along with a very different construction, it might actually mean something. And it's really cool having the rubber seal pre-greased.
Jerry
#39
I've been following this thread with interest. I've read the entire thread and the article, and I've looked at the pictures. I don't change my own oil, but my Lexus dealer will let me bring in my own parts. I understand that the primary difference between the two filters is that the imported one has better filtering material, but does that mean that the non-imported filter has bad filtering material? When we go to the pool, we put SPF 30 sunscreen on the kids. Sure, we could use SPF 45, but every study I've read says that SPF 30 blocks all of the harmful rays and anything above 30 is overkill. So, my question is simply "Is the imported filter overkill?"
e
e
#40
Great point e, but I think at $20 it would be overkill. Oil being one of the MOST important things you can do for your car, maintenance-wise, there is no overkill for me. If I could find the one filter that kept the oil immaculate, and it was around the same price as the stock one, I'd use it.
#42
Forum Administrator
I don't fill up my Lexus with 91 octane when I can get 93 down the road even though it costs a bit more. I don't by cheap air filters for it, I don't buy brand X peformance tires for it. I use synthetic oil instead of perfectly good dino even though I get it changed 3,000 miles or less. Will it run on all those things? Absolutely. Will it run as long as it does on the better stuff I pay more for? Probably so.
Am I going to buy some of these filters and use them instead of aftermarket or cheaper OEM alternatives? Yes.
Make your own decision based on your own criteria. I don't work for Carson, I don't even get paid for what I do here on CL. I've done my research and know these are worth spending my money on them.
#43
Then theres the fact that this filter is no longer sold in the US (via a dealer at least) and if u want one, you have to special order it via a lexus/toyota dealer from japan, which, once including shipping, wouldn't be cheap.
So Carson Toyota is doing a favor to those who want the best and it is $11 for something you change maybe 4-5 times a year that will save you THOUSANDS on engine replacement.
Also, by using a Toyota filter, if something ever goes wrong, you one of the (soon to be the) worlds largest and (currently and forever) most competent car company in the world to back you up.
#44
Check this out guys, interesting...it's a discussion about the Toyota 90915-20004 oil filter vs the Mobil 1 equivalent (M1-102 I believe):
http://theoildrop.server101.com/cgi/...c;f=6;t=001533
